Results 1 to 10 of 12
Thread: Baby seat bolt location
    Hobart Tasmania
    Can someone tell me where the bolt is fastened for a rear facing baby seat. I like to place it on the backs seat behind the passenger seat.
    Thanks,
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by stooge View Post
    Thanks,
    Most of the early (at least up to 1986) Range Rovers don't have one.
    Go to a restraint fitting station, they have fittings to fit the points into cars and vans without them.
    Diana
    Douglas Park, NSW
    My 87 & 88 RRs dont have the restraint points but the later (early 1990s) do.
    I was given details of the genuine bracket (BTR453) & also looked at one in a 1993 RR that we had here.
    The genuine bracket is just made out of folded sheet metal & it's very weak (you can flex it by hand). I copied the design but made mine out of 4mm steel & reinforced the upper body where it mounts. Mine ain't moving .
    I have photos that I was going to put in the tutorial section .......someday.
    Rangier Rover Guest
    If you make your own it should be inspected or things could turn nasty. Even if its stronger than genuine.
    brisbane
    you may need a special mount
    hi there
    when i had my rangies there were no mounts supplied & i had a specially built one in the first one (two door) & a commercialy made one in the four door.
    i still have the second one here if you need to buy one?
    they can be quite expensive like all kid related things but essentially they bolt into the floor & have a post coming up with a baby mount clip ring on the top & sit behind the seat. it takes up a small amount of space & can be either removed or folded down when not in regular use.
    i'll see if i still have a pic of one.
    St Helena,Melbourne
    4.28 MB
    My 85 rangie had one fitted in one of the holes that the xmas tree clip goes in to hold the hoodlining up rear lhd side, my done professionally and lined up nicely with the hole in the cargo barrier for the strap.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Hobart Tasmania
    Thanks, ill talk firstly to the RACT guys and see what they say. If I have any issues ill let you know and see how we can proceed. Cheers.
    South East Tasmania
    There is a shop in Sprigfield Av cnr of Burrows Av, Moonah which are qualified for all these type of jobs. They approved the third seat in the Mazda motor home
    Douglas Park, NSW
    Quote Originally Posted by adnic View Post
    I have one of those that Lokka kindly donated to me before I went the other route.
    You're more than welcome to it for the cost of postage.
    If Stooge doesn't want it, that offer is open to anyone else.
    Hobart Tasmania
    Scouse, I would like it please. Ill PM you my details.
