Results 1 to 10 of 11
Thread: Truspeed
    Zute Guest
    Truspeed
    Anyone know where I can get the "Truspeed speedo correction unit" from in Australia. Im in ACT.
    Also if anyone has come up with a better solution, do tell.
    Invermay Tasmania
    I think Marks 4wd makes a similar product
    Marks 4wd Adaptors Home Page
    Adam
    Oct 2003
    Gold Coast, Qld.
    or try a gps first See how far the speedo was out before you changed anything.
    Checked a gps against my sisters bmw a few weeks back and it was out 8k and was stock
    RAAF Tactical 200184 & 200168
    RonMcGr Guest
    As Outlaw says, use a GPS, even if you have to borrow one.
    I discovered that our Discovery is correct up to 80, then goes haywire. Speedo reading at 100kph is actually 95 kph.
    No wonder I never get booked for speeding
    Gold Coast, Qld
    4x4 Design & Engineering in NSW somewhere from memory - Michael Samootin. Great little unit that allows you to run 2 sets of different dia tyres and is so easy to callibrate making your speedo very accurate.
    Aye, Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Hi Zute,
    Do u plan on running bigger tyres?
    At the moment i run 265/75/16 MTR's on my D2 & the speedo is out 10%.
    So if i am running at 100Km/h i am actually doing 110Km/h & at 60Km/h i am actually doing 66Km/h.
    I have the truespeed fitted as previuosly didnt have a GPS & the wife was driving the vehicle, i now have the GPS but the truespeed does help.
    Especially after u have had the tyres for a while u just get in & drive.
    Try Simon at 4x4intelligence.com.au they will most likely have one.
    Hope this helps.
    McDisco Guest
    Mate as Sniegy said. I have one from 4x4intelligence and it arrived really quickly. They are easy to fit too...
    Worth the money too...only takes one speeding ticket to regret buying one!
    Angus
    Zute Guest
    Oops didn't realise 4x4intelligence was an Aussie web site. thought it was UK.
    Yep going bigger tyres and with standard, its right on the money. I would go the GPS option, but the wife drives it most of the time an not to technical.
    Thanks all.
    McDisco Guest
    yeah they are all local Melbourne guys and they love their Discos!
    Angus
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by RonMcGr View Post
    Seems to be common the D1's, mine is 5-6 % out across the range, i can sit on 110 by the speedo and not get booked - gps tells me if i'm speeding.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
