a few tips I have learnt may help.
1.give the plug on the bottom of the fuel filter a good spray of WD before trying to remove, it can be a real tight bugger and if you slip you'll break the sensor wires.
2. to save removing the engine(just about) to get to the oil filter I generally grab it with a set of long handled multi grips to undo it, a hell of a lot easier then mucking around with filter wrenches in a tight space.
3. Be very careful how you do up the centrifuge cover bolts, not to tight.
4. Make sure you have the right copper washers to replace the ones on the sump bung and gearbox drain.
5. And one more, I'm 6 foot and I have a timber cube 12inches high and 18" square that I stand on when working under the bonnet, makes it a hell of a lot easier.
The Ugly Duckling-
03 Defender Xtreme, now reduced by 30%.
a master of invisibleness.
