Results 1 to 10 of 11
Thread: Flappless 86 county
    Oct 2007
    Flappless 86 county
    Has anyone converted an airconditioned county (yuk) to the manual airvents (front flaps?)
    WA
    A few people - and I think some have posted threads on it - search.
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by Robert View Post
    Try this thread county vents
    Diana
    May 2002
    Sydney, Australia
    D110V8 is your man - hes just about to do his second in as many years.
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Bracken Ridge, Qld
    Why bother ? Sell the County with air con, ad buy a Defender.
    Unless its a 4bd1 - then I can understand.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Newcastle
    i did mine not so long back, pretty easy job.
    you will need the bracket that sit's behind the dash for the handles to attach to or you could modify the one you have, obviously two handles and two vents.
    you will need to cut out the section for the vents as on these aircon models they weren't cut out at the factory.
    i also bought myself some thin heavy duty flyscreen from bunnings (ally i think) and cut it to shape and stuck it to the inside of the bulkhead behind vent openings to help stop all the crap from coming through.
    jason
    Toowoomba QLD
    I have done it twice - and just recently to a spare 110 firewall. There are about 40 spot welds to be drilled out which hold the blanking plates in. Total overkill
    I plug welded each hole and welded on hinges for the vent flaps. Hinges and flaps came from a series vehicle - you have to drill out l the spot welds to remove the hinges from the donor firewall. Its all much easier when the firewall is out of the vehicle but thats a big job in itself. Because my firewall was bare, I had it sandblasted and sprayed in organic zinc. I then resealed all the seams with Sikaflex, applied top coat and filled the cavities with fishoil. Its now in storage..........
    Mar 2007
    I will be doing it soon, but I sort of cheated. I have an '85 Isuzu County with air con. I bought an '85 V8 County without aircon and with a better body. I plan to swap the motor and box
    Anyone wanna buy a V8 engine..........
    Toowoomba QLD
    Quote Originally Posted by Dave_S View Post
    Are the engine mounts on the chassis the same on Petrol/Diesels?
    I have a feeling they may be different...
    Cessnock NSW
    G'day All, The engine mounting points are different cheers Dennis
