Thread: The Vanity of it all
    Nov 2007
    ACT region
    Once the inside of the Streak has been sprayed out and is looking the good I dont want to be re using the daggy old gear knobs, so we will require new Knobs x 3, various boot for handrake, Hi/Lo, Gear shift I have heard the gearbox one isnt made anymore, are they all the same holes from the 1 to the 3, and lastly do the pedals that come up through the floors have A) dust seals and Pedal rubbers themselves, just makes the finished job look that much nicer
    Foot of the Otways
    Hi Mate , I have seen the dust seals and rubbers for the floor pedals on UK ebay for not much if you want to check that out ?
    Nov 2007
    ACT region
    Ok so pommy Ebay is worth a look buy the4 sounds of it
    olmate Guest
    I saw the same ones tonite. The rubbers etc can be bought thru 4wd in Melbourne for not much and they really tidy the inside up.
    I used a 'Preval' spray pack from the local PPG outlet to spray the interior. It comes with a screw on 150ml glass reservoir and they mixed the correct paintthat I needed. I think I paid $60 for 1 litre and that was more than enough to respray the interior of olmate and 5 rims etc.
    Doing the same for the ol ute . For a bloke such as myself who cant spray paint to save his life - its easy and quite forgiving.
    Alderley, Qld
    I got a set for my 2A off Garyclr4wd from Ebay. He is down the Lower Blue Mountains area. Nice guy and good to deal with.
    Russ
    Oct 2007
    Usually in Griffith NSW
    You need the pedal shaft to run nice and centrally in the hole or the rubbers dont look so good.
    I think there were felt pads originally under the rubber, but I dont have a parts book handy to verify.
    Nov 2007
    ACT region
    Painting for me is no great drama as I am an industrial spray painter by trade, I have my dads really old Sunbeam Low pressure compressor and an equally old Binks Bellows low pressure gun, spraying air dry enamel at low pressure really gives you a nice job and you dont need to be a pro, even one of those airless chatter guns made by Oldfields(Krebbs) will do a job good enough. Those little glass jar sprayers you describe Troy work very well, proven design been around for years. From what I could see in the Pic she looks pretty sharp.
    Narre Warren South
    Mine still has the original rubbers and yes there is a felt disc that fits inside them.
    This allows for the fact that as the pedal moves it doesn't stay exactly in the centre of the rubber.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Nov 2007
    ACT region
    How are the pedal shaft rubbers fitted out of curiosity?
    olmate Guest
    How about this on ebay:
    "]http://cgi.ebay.com.au/land-rover-series-1-Pedal-Grommets-and-Felt-Seals_W0QQitemZ150220243538QQihZ005QQcategoryZ6763 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem[/URL]
