Thread: Thoughts On Adjustable Steering Damper
    Victoria, Geelong
    Question Thoughts On Adjustable Steering Damper
    I'm looking to replace my old original steering damper because I was told to do so as the standard ones are **** week and leak etc.
    I found this on ebay 4 Way Tough Dog Fully Adjustable Steering Damper has anyone got one in there Landy or know of someone who does and is worth buying.
    Firstly I doubt if you'd ever adjust it. Secondly, you can pick up a Bilstien damper for less. Thirdly, there's nothing wrong with the standard one's for most driving.
    Victoria, Geelong
    St Helena,Melbourne
    4.28 MB
    Just like of have adjustable Koni shocks, in 6 years on 2 vehicles i have never touched them. Save your money, as DM said the stock damper if in good nic will be fine.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    McDisco Guest
    I agree. The steering geometry and dampening of a good quality replacement will be fine. Only Patrols and Landcruisers need adjustable ones...
    Spend your money on something else...
    Angus
    Karratha WA
    Hi,
    I run a Tuff Dog Return To Centre (RTC) one and it takes the shimmy out of the front when the weight of the caravan is on the back. The RTC one is great, I can vouch for it.
    The adjustable valving one is just on the market but if you have to use the adjustment to compenstae for wobble in the steering wouldn,t you get the problem fixed any way. (i.e. Death wobbles on GQ Patrol).
    BradM
    May 2003
    On The Road
    I replaced the original with a Bilstein on my D1 in '98?? never thought about it again.
