Thread: running a boom box on 12volts
    May 2003
    On The Road
    so, we now have lots of 12V goodness in the camper,,
    and a perfectly good
    small (240V/battery ) cd/radio/tape boom box.
    what the best way to get the boombox to run off our 12v 2 pin outlets?
    it has no external plug for power other than 240.
    May 2006
    Carlton, Melbourne
    Pedro, how many batteries does it take? if it's 8, then It's easy as 8x1.5v is 12, you just need to either connect to the correct battery terminals in the back, or (more proffesionally) open the boombox and wire in an external power socket.
    if it's not 12v, then a small regulator circut can be built in the back of the boombox to drip the voltage to the right level
    Fraser
    Someting like this:Jaycar Electronics
    What he said ^^^^^
    12v wire it up n plug it in !
    I suppose you might want an inline fuse. Maybe use crocodile so you don't destroy the original contacts for the batteries.
    May 2003
    On The Road
    Quote Originally Posted by HangOver View Post
    What he said ^^^^^
    Too late!!!
    May 2003
    On The Road
    anyone guess at the current draw for a cd player pumping through two 2" speakers??
    (and yes! there were 8 batteries!!)
    May 2006
    Carlton, Melbourne
    it would be insignificant by car standards, it should have it's power consumtion on the back, and in reality, on batteries they use way less than that.
    I would guess in the region of 350-500 mA, less than 1/2 amp at any rate
    Fraser.
    May 2003
    On The Road
    Boombox worked a treat at Cooma!!!
    Thanks Everyone
