Results 1 to 9 of 9
Thread: Conversions V8
    Jan 2008
    NSW riverina
    Conversions V8
    Hi to all.
    Im new to this type of question and have tried to find out what type of V8 conversion can be done to a 130 defender.
    Chev 6.5 ? and who in QLD would do this type of work.
    One more question. What causes the thumping noise when you let the clutch out ( have had the new toy for 3 mths )
    and is it going to cause any damage if left alone.
    In regards to the conversion dose any members have Photos and a price of the work done.
    RonMcGr Guest
    peachey80 Guest
    Are you wanting petrol or Deisel ?
    Wheelers Hill, Melbourne
    I would get under your car with a tyre lever & check your engine & gearbox mounts for that thump. You will fracture the others eventually.
    David
    May 2006
    Woolgoolga
    RonMcGr Guest
    Jan 2008
    NSW riverina
    Thank you for your answers.
    Prefer Diesel and I have been under the toy with a lever and there solid ?? would it be the diff ?
    And I have sent an email to linquip but no reply ( must be busy )
    Once again cheers
    And is it a big no no with the conversion buy doing that to a landrover
    May 2006
    Woolgoolga
    Quote Originally Posted by blue juice View Post
    Once again cheers
    Yeah 13k for a motor off them, you could rebuild mine 3 times for that, or stick low comp pistons in it and run the turbo with a bit more boost, 200kw/ 700Nm, you know you want to
    Avoca Beach
    The thump could be worn ball joint on the back axle, worn leading/trailing arm bushes under front or rear axle. Loose UJs, worn gearbox to transfer splines,worn clutch plate springs.
    And the list goes on.
    Regards Philip A
