Results 1 to 10 of 35
Thread: Rear Indicators Upgrades
    Victoria, Geelong
    There has only been one major concern when I brought my 1995 Land Rover Discovery and that was the rear indicator's are only on the rear bumper bar and the earlier models has them included into the brake lights later on.
    What I am wanting to find out has anyone made there own mods to allow the earlier model be fitted or have some of you got extra lights put on so drivers including truck drivers can see that you are changing lanes or turning.
    Pics of mods etc would go along way.
    Mansfield, Victroria
    I have a '93 disco, i soldered a diode from the brake light to the red "fog" lamp thus turning it into another break light in the cluster - i would like the bumper bar with the lights as well - just to light up a little more....
    also have reflective tape on the back of the diff and axle..... can do a pic if ya want one
    mick
    Mick
    Victoria, Geelong
    You missunderstood there is a lack of proper indicator's on this model the only ones are on the bumper bar I need a pair higher up so they are properly visable by all.
    Jul 2003
    Quote Originally Posted by AussieLandRover View Post
    I think you will find that the 96 model onwards had the lights in both places....so a trip to a wrecker will get you the correct light for the body and some wiring tricks will get them to work...
    In 11 years I haven't had anyone run into the back of mine because of this "major" problem.
    Mahn England
    Ex 300Tdi Disco:
    Dalby
    The pre update model has all the tail lights in the pillars.
    The update model of about 94-95 has the indicators and tail lights in the bumper and brake lights and reverse lights in the pillar.
    The update of about 96-99 had the full set of pillar lights as well as the bumper lights.
    So if you get the older or newer tail lights and do some wiring then all will be well.
    I ran wires to the tail lights in the pillars (which are in the dual filament bulb with the brake light) so I at least have tail lights in the pillar.
    Douglas Park, NSW
    Be aware that extra indicators will have your Disco thinking you have a trailer connected & flash the trailer warning light with your indicators.
    There are ways around this little problem - the easiest being LED globes.
    Dalby
    Scouse I have never considered this before but are there two different flasher cans for the models with only two rear indicators (whether in the bar or in the pillar) and the model with four rear indicators?
    Yinnar South, Vic
    Or 5w globes
    Douglas Park, NSW
    Quote Originally Posted by Utemad View Post
    I have heard that is the case but I have never checked it myself. I'll have a look see tomorrow .
    Dalby
    Thank Scouse. It would mean that for those of us with only one pair of rear indicators that we would have another option when fitting indicators in a bullbar.
