Results 1 to 10 of 11
Thread: rust in a disco
    Foot of the Otways
    rust in a disco
    Is it possible to get a disco 95-97 without rust or is it just a given ?
    Colac foot of the otways
    Quote Originally Posted by wannalandy View Post
    I think its just a given,My 91 has no rust just lots of scratchs.My old 95 had rust around the alpine windows.If you keep looking i'm sure a good one will come along.Cheers Brett
    Oct 2007
    the 95 I picked up has no rust.
    Xav
    Dalby
    My 94 model only has a bit of rust in the passenger front footwell floor. Well that's all I know about anyway. Rusted from the inside.
    I've cleaned it up though so I guess that means it doesn't have any rust that I know about
    RonMcGr Guest
    My 97 has no rust what so ever
    Treads Guest
    Mine had a small spot of surface rust on the drivers side A-Pillar top, which I fixed today, and some more in both front footwells. I'm in the process of fixing the cause (heater matrix leak) and will treat the rust tomorrow.
    What do people recommend as a good rust treatment?
    Island
    My 97 V8 has no rust (and will be on the market sometime soon).
    My TDI has very little.
    Williams West Aust
    D1s
    the alpine windows and the roof rails are fairly common.
    LOOK UNDER THE REAR MAT.
    If its a UK private import chances are the floor will be rusted out due to the salt used on roads.
    Others have posted on rust behind the front gaurds.
    If the roof isnt rusty,chances are its either been fixed(look for too shiny paint for age) or been garaged/from a dry area(one to look for)
    The D2s dont suffer from Alpine window rust,the seal was changed to a type that doesnt hold water.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Mar 2007
    South Arm, Tasmania
    The only appearance of rust that we ever found on my 95 Disco was on the rear floor (inside) when the Mrs pulled up the mat one day.
    This was paint surface rust only, and actually wiped off with a wet cloth.
    Never had any other issues with it.
    Cheers .........
    BMKAL
    Victoria, Geelong
    I brought my 95 Disco a few months ago and I can see no rust at all and I checked all the common area's you will find rust and there were none to be found so I brought it.
