Results 1 to 10 of 22
Thread: Info on GPS Nav System needed by NOVICE
    Moruya Heads/Sth. Coast, NSW
    I know nothing about GPS Nav. Systems, do Know not all are able to use or have downloaded to them maps that show all the firetrails, which is what I need.
    Now dont laugh, Aldi's have a GPS Nav. System on sale from the 10th April, details as follows:
    Brand Name, TEVION
    3.5" LCD touch screen
    400Mhz speed
    512 Mb built-in memory
    Atlas 3 CPU
    Navteq Mappimg Version 7
    Speed camera and red light camera warning
    Photo Viewer
    Includes car charger and windscreen mount
    USB cable and Stylus
    Position accuracy under 10M
    MP3/MPEG4 function
    $179.00.
    Question can I download Aussie Maps showing fire trails to this unit, if so what program would I get , where and how much, at the moment it is all I can afford, any and all information will be greatly appreciated, Thanks in Advance, Regards Frank.
    Dalby
    You would not be able to do it out of the box but it is possible that it would be similar to the unit that this was done to.
    Bargain GPS - Patrol 4x4 - Nissan Patrol Forum
    If you want to use Oziexplorer CE to use maps like you mentioned then generally the way it is done is to buy a PDA and bluetooth or CF GPS (or inbuilt GPS).
    I should add that if you buy a secondhand PDA from Ebay ($50 and up) plus a GPS to connect ($50-$100) and Oziexplorer CE ($35). Then you would have a good system. If the PDA doesn't come with one then you would also need a car charger and I'm sure you would be able to knock up a cradle. Plus an SD card. 1 gig is pretty cheap these days.
    The full OziExplorer for the PC is about $130 and even though it says you need it if all you want to do is get ready made maps and see where you are on the map and make waypoints tracks etc then you don't need it. It is recommended though as it expands your capabilities greatly.
    Actually if you have a laptop and can run it in your vehicle then you can plug any sort of GPS into it with Oziexplorer and use that.
    Perth, WA
    No commercial in-car GPS (Other than the Magellan Crossover) will let you load offroad maps. (This might be with the exception of the large Garmin 7200's and the like, though until I get one in the US and have a play, I'd hate to state they could be done!!)
    Some CE based ones can be made to run other stuff, but the only real way to find out is to buy from somewhere you can have a play and take it back if it doesn't do what you want, or google for the one you want to buy and see if anyone else has done the same thing. Not really novice type stuff though if you're not PC literate and used to playing with files, memory cards, loading software etc. However, some of the HowTo's people post up are very good and step-by-step based.
    The link just posted looks good though, and I think for the outlay (Considering I have Ozi already) might just be worth playing with.
    Jeff
    1994 300TDi Defender
    2010 TDV8 RRS
    St Helena,Melbourne
    4.28 MB
    PDA is probably the best option to use for both street nav and mapping, i use an ipaq with Tom Tom and Ozi ce and love it - i leave in the car permanently.
    As jik22 said some of these cheapies have been able to load ozi so for $179 ift would be worth a shot, if it uses winc ce as an os and has a usb connector and able to use active sync you are most of the way there - searck on the GPS Australia forum as some guy has been able to run ozi off an sd card without installation to the unit.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Thanks all for the Info, I've been googling around a bit on this Navteq Version 7 it seems they supply the Nav system to Nokia 6110, which my son has/had and it showed all of the Firetrails around here some which were not on any maps, so it would be nice to have a trial run, but these things will sell out at Aldi in the first hour they open, so if anyone out there has one and used it, would love to hear from you, Regards Frank.
    Im using the mio digiwalker A701 phone pda media player and GPS all in one.. ITs a real Sirf III not just a CDMA wannabe..
    Its done everything I wanted it to when I bought it and when I get done talking with ron hopefully it will find another capability to add to the list of ones Ive already got it doing that are above and beyond its purchase specs.
    Perth, WA
    Quote Originally Posted by Tank View Post
    If they have a decent returns policy, just buy it and have a play.
    Jeff
    2010 TDV8 RRS
    Quote Originally Posted by jik22 View Post
    Jeff, the way to go, let you know, Regards Frank.
    I thought about buying it as my copy of jsp's nav system is no closer to fruition. I have Destinator running on my old PDA but it's as reliable as a two-bob watch. Nay, less reliable. When you need it, it stops working. The PDA is OK, but the nav system isn't.
    The number of times it give ridiculous instructions is amazing.
    Fortunately, it has a woman's voice and both my wife and I can laugh that the bird in the nav system is a typical woman and couldn't navigate her way out of a paper bag.
    I've driven into Sydney and back (120km) before the system got a satellite lock and decided she knew where we were. I knew. I was home again.
    Don't ask me how often she gets our location wrong and thinks we are on a different street to where we should be so starts issuing commands to get to where she thinks we should be.
    I went to Pavo's place last week. She told me to turn 20 metres after I'd passed his street. As I drove down the wrong street she told me I had arrived at my destination.
    When I went to Abaddonxi's place she took me via the most circuitous route available. When I got there, I found he was 150 metres down a side street off Parramatta Rd - the road she'd taken me off!
    If the Aldi unit is no better than mine, then you end up like me and regularly almost at the point of smashing it against a wall.
    Then there are the maps. In Sydney, you'd need regular map updates otherwise you'll get led up the garden path as she tries to take down one-way streets, into closed off roads.
    I can see why there are an increasing number of stories about people driving into rivers, into the sea, onto railway tracks as they follow the dumb bitch's instructions!
    Ron, Aldi has a good returns policy, I bought a cheap $100 Metal Detector, had it for about 2 weeks, couldn't sort it out so I took it back, no questions asked, handed over the refund, so I reckon this Sat. Nav. is worth a try. Navteq supplies Nokia 6110 phones with the same system on this gizmo so if it works the same I'll be happy, Regards Frank.
