Results 1 to 10 of 13
Thread: Water Sound ??
    Sharpie Guest
    Water Sound ??
    Hi My d2 is for some reason making this running water sound every time you take off it has water or something running from one end of the car to the other and the same as when stopping can anyone point me in the right direction as to what this might be and how to get rid of it ??
    Cheers.
    May 2006
    Carlton, Melbourne
    I'm not familiar with Disco's specifically, but I remember a few of the cars I owned in the past (falcons, valliants etc) the drain holes on the inside underside of the doors could block up with general road grime/little leaves, and the doors would fill up with water after a heavy rain. There is probably 2 holes or slots there. I used to juggle a short bit of coat hanger wire in them till they unblocked. Water sounds was how I noticed it.
    do it soon otherwise your doors will rust up very quickly.
    Once they are empty, you could use compressed air to give them a good clean.
    Let us know it this was the cause.
    Fraser
    Warburton, Victoria
    Drain holes in the doors have plugs and leave them out....
    Rain gets past the window seal and fills the door up...
    Get under the door and i think from memory the door had 3 or 4 plugs the size of 10c coins... pull them out... and leave them out..
    Sill does not exist as such, so there will be no problem there....
    Jan 2008
    Grange, Adelaide
    Quote Originally Posted by sclarke View Post
    I reckon this is good advice and looking at sclarke's avatar, Id reckon he'd know.
    Water sound above your head, now that's different found that one out when I used a high pressure cleaner (twice), ('cos I didnt believe it the first time). Twit!
    May 2003
    On The Road
    Stop the car.
    check coolant levels.
    do it NOW!
    water sounds from the dash of a D2 is a sign of low coolant.
    IF this is the case---
    go here-
    http://www.aulro.com/afvb/common-thr...2-coolant.html
    Sharpie Guest
    cooling system is AOK nice and full and with the doors there are no plugs to pull out and all the holes are nice and clear so there is no water in the doors.
    The sound seems to be coming from under the car (and no i haven't been in any rivers of late) like it's draining from one spot when taking off then as you're braking filling up again ??
    this has got me stuffed !!
    Williams West Aust
    BLOCKED AIRCON DRAIN(S)
    Get underneath,2 rubber hoses with a "bulb" exit either side of the trans tunnel.Squeeze rattle stick a stick up them.
    BET YOU GET WET
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Sharpie Guest
    well it seems to have been the water reservoir, I've overfilled it and for some reason the sound has now gone away for now !!
    so thanks for your help.
    May 2003
    On The Road
    yea,, while there's no expansion chamber as such, the coolant top-up resevior does only move slowly,,
    I'd go to COMMON THreads,
    D2 Coolant
    and use the flushing guide as a water top up guide.
    Rockingham, Perth
    Even though the reservoir is full there is an air lock in the heater matrix and lines. keep topping it up and squeezing the lines. It took me ages to get rid of the air lock.
    Another symptom was the heater going from hot to cold all the time, generally it was hot when moving and cold when stopped. It didnt happen all the time though.
