have you actually got spark to the individual pistons? grab a spare plug, earth it and hook the HT lead to it first direct from the coil and then to the pots one at a time.
this works best if you crank it over by hand as then you have max volts arriving at the coil.
If you have no spark coming out of the coil you might have something as simple as a short circuted or open circuted condensor or a brake in the wiring somewhere, have you mulitmetered the coil yet?
are you getting fuel to the carby? to check this take the horn(filter) off of the top of the carby and look down the throat while you whip open the throttle by pulling the linkage. If you get no fuel you have something wrong with the supply part of the carby or the fuel system, take the fuel line off of the carby and manually pump or crank the engine over and see if you get fuel coming from the line. If you dont its time to fault find the supply system.
Check this stuff out and get back to us and we'll see whats next.
Im fairly mobile as a mechanic depending on where your located can probabley do a late night run tonight.
Pm me or check your PMs for my phone number and give us a call, Im about due for some series spanner twirling. Best thing Is I can claim this repair job under ignition systems which I still have owing on my workbook.
In = Richer, OUT = Weaker
