Results 1 to 10 of 26
Thread: V8 Gas conversions
    Dugsley Guest
    Question V8 Gas conversions
    I'm researching fitting an LPG system on an '01 S II 3.9 manual. Sorry if this has been done to death in the forum, but i searched a bit and couldn't see much.
    Obviously I want to miss Ruddy's probable axing of the rebate, and have been quoted $5 300 for a 'Tartarini' system, whatever that is. I've been quoted a lot of other junk too... how some businesses survive is a wonder.
    What should I need to know? Are there better systems than others? At less than 20 000km per yr is it worth it? (I currently get about 15L/100k's highway).
    Thanks for any advice.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Dugsley View Post
    Tartarini is an Italian brand of lpg components, at less than 20k per year i dont think the cost of the conversion is justified. For a DII you really want an lpg injection system not a crude earlier type, 15L/100 is pretty good and lpg will run at at least 20+L /100 but at less than half the price of petrol who cares. One thing i found was once i converted to lpg i tended to drive more and further because i could .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Where are you located? It might help with pointing you to a fitter.
    Dalby
    If you are going to keep the car for a while then it could still be worthwhile. You will be kicking yourself for not doing it earlier if you end up holding on to it.
    By the time I converted mine it could have paid for itself but mine was only a $1500 setup after the rebate.
    Although don't be too concerned if you miss out on the rebate as with any luck the prices will drop when/if it is revoked. They certainly skyrocketed when it was introduced. My quotes went up by $1000 after the rebate came into effect.
    Safety Bay
    I got mine done at Hunter Gas Technologies.It was $4300,LPG Fumigation with twin under sill tanks.I had to change plugs,leads to get it to run smooth but it is a good thing. Pat
    Quote Originally Posted by PAT303 View Post
    Umm, sequential gas injection? Fumigation is usually used with diesels.
    I have the same system as they fit - the KME unit.
    Safety Bay
    Ignore me. What he said. Pat
    Dugsley Guest
    Thanks! I'm in Albany on WA's south coast, but would travel to Perth to fit, i imagine. Thanx!
    Dugsley Guest
    Yep, The Tartarini is an injection system. You're exactly right, it's being able to afford to use Dugsley more, and save the 2nd car!
    Safety Bay
    I'm getting the defender hooked up with this years tax cheque and there was a place that ran a full page add in the west australian or sunday times I can't remember that had it for $4500 with a $3000 rebate and also an interest free repayment plain off $88 a week for the $1500 owing.They were in Perth and it was less than a month ago. Pat
