Results 1 to 10 of 11
Thread: Nanocom pc interface "cannot init ecu" error
    Ok, I've been playing with the nanocom for a bit now. It mostly works nicely. When just plugging the unit in itself it only gets the "error cannot init ecu" occasionally and this is usually solved by turning the key to the second position.
    However my problem is that when using the pc software I plug in and everything is working then I'll us it for a bit and then it just gets "error initialising ecu" (or something similar). The unit has remote on the display but nothing else really changes.
    The only way around this seems to be to unplug the unit, shut the software down and start again. Even then it's fiddly. Am I not doing something correctly?
     2005 Defender 110 
    Blairgowrie, Vic
    Get in contact with tech support at Nanocom, outline the problem and await their reply. It's normally very prompt.
    Pete
    Dizzie, 08 D3 TDV6 SE
    Williams West Aust
    Are you using a USB/serial port converter???
    Not sure where I read it but there are issues with some of the cheaper converters.
    Cant wait to get hold of my Nanocom,sick of the 3 stupid lights on my dash!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Yep I'm using a serial to USB converter. I should also confess that I'm running it on a mac running XP under parallels (I really don't think this is the problem though).
    But you've got pretty graphics when it gives you that message right?
    Quote Originally Posted by Aukedrdw View Post
    Yeah... pretty much. Is no one else having this problem?
    Apr 2007
    I am lost
    i have recently got a nanocom and i am getting the same :error cant inniciate communtication with ecu or something like that it seams to only do it when i am checking faults on the D2 abs/sls unit is it something i am doing or some sort of fault
    cheers kelvin
    Adelaide SA
    Quote Originally Posted by disco_thrasher View Post
    i have recently got a nanocom and i am getting the same :error cant inniciate communticating with ecu or something like that it seams to only do it when i am checking faults on the D2 abs/sls unit is it something i am doing or some sort of fault
    cheers kelvin
    Whilst we are sharing the love, can you tell me where you got your Nanocom, and the cost???
    Apr 2007
    I am lost
    wa rovercraft 500 bucks hurry if ya wanna buy cause i think i got the second last one
    Try turning the wireless off on your laptop. I think this helped, but I'm not sure if it wasn't just co-incidental.
