Results 1 to 6 of 6
Thread: D1 speedo accuracy
    St Helena,Melbourne
    4.28 MB
    D1 speedo accuracy
    Went out to Warburton/Nojee on an LROCV run today after doing the camel cut to the rear guards and fitting my set of steel rims with 265/75/16 MT's, on the way up on the highway using my gps i reckon my speedo was close to spot on maybe 0.5 kph under but close enough to rely on the speedo alone.
    Also was surprised how little performance i lost with an almost 3" taller tyre, really only noticed it on a long uphill section at 80kph and needing to boot it to keep momentum up .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Dalby
    I found mine is spot on with 255/70 16 as well as 245/75 16.
    NSW , Pennant Hills
    Quote Originally Posted by Utemad View Post
    Ditto x 2
    Jul 2007
    Hobart Tassie
    loanrangie
    i run 31's and i thought my speedo was out by 6/7 klms
    but using my gps its reading the same...?
    Southern Adelaide
    my d2 is near on, perfect(actually reads a bit slower than actual with the standard tyres at 50% worn. this is throughout the speedo range. with a peculiar "slow" reading at around 70-90.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by smally4.6 View Post
    loanrangie
    Thats about right then, 31/10.5/15's 245/75/16's 265/75/16's are with an inch of each other or there abouts.
    1974 VW Kombi bus
