Results 1 to 10 of 13
Thread: Window winder Disco1
    easy Guest
    Hi I'm after the front passanger window winder mechanism without motor.
    Any sugestians of where to buy? Discovery 1998 SE:1 So fare been told between $170 to $230 for a peace of tin.
    NSW , Pennant Hills
    Quote Originally Posted by easy View Post
    Hi Easy;
    Try Triumph Rover spares i think 08-83846933
    Kyabram, VIC 3620
    What is the problem with the original, there are some useful posts on this forum to repairing these.
    easy Guest
    Two of the nylon rollers came off.
    How do I find the post's for repair's?
    Thanking you ladas
    Jul 2003
    You could try a search (button located in the main title bar above).
    Enter the word "window" and wade through the results....you will probably find something useful. Good Luck!
    Mahn England
    Ex 300Tdi Disco:
    British4WD.com (also on eBay), got one for my D2 (same part #'s as a D1) the other month - $118. Mine was too stuffed to look at repairing.
    Kyabram, VIC 3620
    Thanking you ladas
    There are two or three good threads here on replacements for the nylon rollers, you can get as close as from places like Bunnings - (one of the treads shows the part numbers/picture) and you can just breplace them for about $5.00
    From what I can understand the replacements are often better than the originals.
    Sorry I haven't the time at the mo, but just do a search for broken window - window winders - etc., etc., there is a lot of info out there.
    Jul 2003
    Use advanced search and in the keywords section type the word "window" then in the drop down box select "Search Titles Only" (this should reduce the results to 3 pages only!!!!):
    Australian Land Rover Owners - Search Results
    [select icon with foreheadsweat]
    Mahn England
    Ex 300Tdi Disco:
    Kyabram, VIC 3620
    easy Guest
    Thanking you Gentlmen
    As usual you have all been a greaty help.
    Now I'm of to Bunnings
