Ashcroft or Great Basin Rovers, about $1000 landed for both. Or there is a set on ebay. Interesting to see what they go for.![]()
Pete
Anyone got a spare indicator/high beam switch? Mine has melted the plastic bit where the low beam/high beam bit is. To suit an 85 RRC.
Also, does anyone know where and how much are 4:11 ratios to suit?
Carlos
1963 Land Rover Series 2a 88
Pete
2008 Range Rover Sport TDV8
1973 Range Rover Classic "Suffix B"
ahhh, your talking about the 4:11, not the switch that is wbout $1000![]()
Carlos
I presume you know to fit a relay for the headlights to prevent future failure of the switch (once you replace it).
I had a switch fail on me in the worst possible conditions - could have been very nasty. Convinced me to never risk that again.
I had a similar experience with my 1984 RR. Used a double pole relay to switch the lights to high beam as at the time a switch was a costly replacement. Let me know how your switch is behaving, what it does, and I am sure I can give you a quick circuit to incorporate the double pole relay.
Michael T
2011 L322 Range Rover 4.4 TDV8 Vogue
Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
get onto Rimmer Bros in UK, I got a new switch just the other day cheap compared to local suppliers, see link below.. and it arrived in a week. identical to old one in a lucas box...and shinny!.. mine was $29 pounds, = bout $65AUS, yours is a little dearer...
Rimmer Bros. - Product Price Information
regards,
Russell.
LSE up, LSE down.....
1976 5.0ltr P76 2 door Rangie
Might be able to help with the 4.11's shortly
When I have to put 3.54:1s back in
KAM gears to, toughest aftermarket 4.11's there is![]()
out of interest Matt, why are you going back to 3.54's...I assume the 35's are also going....
I reckn you could do a deal with Carlos...diffs AND tyres![]()
Thanks for the replies people, I will look at getting some relays to bang in. Now to find a switch, Rovercare, you got my PM dude?
As for the 4:11's I think that wont happen as yet. Gotta sort out (read spend) other stuff first, like the suspension lift which will effect, shocks, brake lines, swivels to be machined and other stuff no doubt.
Carlos
