Results 1 to 10 of 25
Thread: please be nice... patrol vs disco
    Southern Adelaide
    My brother is thinking of getting a 4wd. he had a swb mq a few years ago, and after a few day trips with me in the disco, he wants to get back into a 4x4 again.
    so far it looks like it'll be either a 96-98 disco 300tdi, or similar year-range patrol 2.8td. really its about spending upto $12k.
    obviously i'm biased towards the disco's. his initial want is the patrol. just because he had the mq and it served him well.
    i dont have alot of knowledge on either vehicle. from whati've read on here, the 300tdi's are looked on favourably, so far i havent been able to find alot of useful info on the patrol.
    he's not one to do alot of maintainence until it "needs" it, besides basic servicing. which car do u think would be the better choice? if the disco, is the auto trans a goodun'? most that ive seen advertised are auto's. not sure if its because they are popular and good, or if its becasue they are tired/worn/about to die and so are being sold.
    he's in the barossa, so his driving is country, open roads and probably several trips a week that are only 10min jobbies to the shops and whatnot. he wont be towing, will be doing some easy-medium off-roading, but just local, something to do, type driving on friends property and rutted tracks.
    thanks for any tips.
    IMHO the autos are a mixed bag but thats common to pretty much every second hand vehicle you purchase.
    The engines are of about the similar vintage and tech so thats much of a much ness for longevity
    The discos body and chassis generally lasts longer than most vehicles of its vintage and its a fair whack better on fuel if well tuned.
    The patrols are a little more comfortable in the back
    Stock discos do better as all rounders and the patrols tend to have it over them on black top and the beach but arent as well behaved on the rocks/gravel + mud. Thats just from my observations and could be skewed by individual driver skills in those areas.
    So far as I can tell theres more accessories and mods for the patrol for customising it to what you need it to do but then for most people the disco is all that anyway its just the shiney paintwork and the carpet that stops people from making it do what it can.
    Highlands NSW
    A 97-98 auto 300tdi disco that's been well looked after is the way to go. I sold manual recently for $10k (should have got more but needed $ asap) Must have full service history as to time belt changes and oils etc ... then get it checked by someone who knows discos. Get your brother to have a water coolant alarm fitted and away he goes. Good luck. A patrol at that price will have double to kms. Should be able to get disco with 150-200k kms that is running nicely.
    2010 110 Crew Cab Deefa
    Mittagong NSW 2575
    Southern Adelaide
    cheers guys. with the auto's, do they wear out gradually, or just one day let go/have sporadic moments of good and then others of crap? i have enough mechanical knowledge to feel a slipping trans, too-harsh up/down shifts, and trying to crawl forwards at idle while on the brakes.
    On road, in my view having driven both, the old Disco is a far superior driver's car. It is more comfortable over rough roads (including bitumen). This applies to the GQ and GU. I've driven very late model Patrols and they are rough in comparison (especially in comparison to my RR )
    The Patrol dhe drivetrain (in 4.2 guise) is very strong. The smaller diesels have, I believe, a lighter gearbox. Diffs in all models are strong and the diff of choice for LR upgrades.
    A 300Tdi is very easy to maintain, especially one without the electronic gizmos like ABS and SRS. The Patrol might need less maintenance
    I think the Disco has a far better driving position. I know my sister was surprised when she first drove my '87 RR - it was, in her opinion, much easier to see out of and more comfortable than their GQ Patrol.
    The Patrol is bigger if he needs to carry a load.
    The ZF auto in the Disco (and Rangie) is very reliable.
    they do both...
    if they are just wearing out and have been well serviced they will give you advance warning and start doing things like putting little metal flags in the oil and filter in the correct semophoric positions to spell out "I am not healthy please send me to an automatic repair shop before I have a terminal heart attack"
    Others that have been overstressed, onderserviced, over watered, over heated and underloved will just one day get upset and decide to take revenge, this usually occours at some preordained point in time and space that will cause maximum cost, embarrasment, risk, inconvenience and frustration.
    the auto in the disco can with even the most mediocre care and maintenance make 200K km.
    Shssshhh! I had nearly 400,000 on my '87 RR when it was sold. And that ZF was behind a 4.6 when it had only been designed for a 3.5 litre.
    I used to stick the boot in, too.
    Yinnar South, Vic
    Quote Originally Posted by simonr23 View Post
    he's not one to do alot of maintainence until it "needs" it, besides basic servicing. which car do u think would be the better choice? .
    By an RD28 GQ, Not GU, don't even think bout a ZD30 GU either
    bet it got serviced properly tho...
    Why just the other day there was a post on just that subject, and here's a permalink to the post!
    Quote Originally Posted by rick130 View Post
    Naa, they come pre-equipped with all the rattles and squeaks, saves you getting the poos when it happens further down the track......
    Seriously, we have a GU Patrol (ute) and a Defender, so I'm possibly qualified to comment.
    Build quality of the Land Rover is crap compared to the Japanese vehicles.
    Simple basics like fit and finish are non existent on a Defender. If fit, finish, etc. are important to you, look elswhere.
    Silly little niggly things fail, like door handle buttons, screws drop out, etc.
    the boys above have touched on the engines. The 300Tdi goes fine once the turbo is spooled, but is a bit doughy off idle. Fuel economy is excellent. They are simple little engines and easy to service and maintain. The only major maintenance is timing belts every 80,000km and clutches last around 200-220,000km. Plates themselves don't seem to wear if the driver is doing his job, but the fingers on the pressure plate, and the clutch fork itself usually fail at around this mileage.
    It is a relatively simple job to 'tickle' up the injector pump fuelling to give the Tdi better oomph than the Patrol TD42T yet still return better fuel economy.
    On standard type tyres (235/85/16's) the driveline reliability is fine, although the front diff and g/box aren't as strong as a Patrol, the older model Salisbury diff (pre '03) would have the strongest centre of any 4x4 on the market, barring maybe the H260 in leaf sprung rear Patrols.
    Axle flanges can be a problem with fretting in post '94 Defenders, as the axles are two piece (separate axle and drive flange) It's a relatively easy fix to convert the hubs to the older style oil lubricated wheel bearings (semi trailers use this style of lubrication too) and this fixes the problem, along with some Hy-Tough axles and flanges (formerly Maxi Drive)
    33" tyres fit without a lift, I've been running 255/85's for years, and these are supposedly 33.3" tall new. (front end has been lifted about 40mm or so)
    Out of the box, a Defender is probably more capable than any other 4x4 on the market, except a Wrangler Rubicon, and rides and handles off road better than a Patrol, although both vehicles can be easily modded for tougher off road use and then it's up to the driver.
    I've had a lot more niggly problems with the Defender than the Patrol, but it was caned by the previous owner (Govt department) but it has never stuck me up. (except when the clutch fork broke, but I still drove it for two weeks without a clutch )
    The GU has been the very model of reliable and quiet transport, has now clocked 280,000km and is need of a new rear axle seal (and bearings ) whch I think this is about the only thing I've had to do since new other than normal servicing.
    The Defender has been a bit more 'involving' than that, but I still prefer to drive the Defender, and do every day as it's my work truck. I'm on call 24/7, so I need a reliable vehicle and the Defender fits my needs well.
    I've never even sat in a Patrol, so wouldn't have the foggiest idea.
    Simon
