Results 1 to 4 of 4
Thread: Valve Clearances "checked" & "Adjusted"
    NSW , Pennant Hills
    Cricky,, all Valve clearanaces were wrong except 1;
    It's very easy to do , BTW this is the first time I've done the valve adjustments myself.
    Filler Gauge 0.203 mm ,
    No 1 Valve adjustment required , too big of a Gap
    No 3 Valve adjustment required , too big of a Gap
    No 5 Valve adjustment required , too big of a Gap
    No 2 Valve adjustment required , tight gap
    No 8 Valve adjustment required , tight gap
    No 6 Valve adjustment required , tight gap
    No 4 Valve Almost spot on , Slight Adjustement required
    No 7 Valve Spot-On
    Alright anyone wishing to do their own adjustments, here is a copy of the instructions I found here.
    Attached Files Attached Files
    St Helena,Melbourne
    4.28 MB
    Do you really need to remove the top rad hose ? i reckon you could just remove the valve cover and check away.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    NSW , Pennant Hills
    yeah you could ,but if the valve clearances are wrong ( as was in my case ) , it's soooooo much easier to crank the crank shaft pully clockwise without the fan ,radiator top hose and intercooler top hose in the way of the braker bar , honestly it's a 5 minutes job extra but you're home. $%$$^ easy.
    BTW I'm installing the jase Intercooler 2morrow ,shoud be awesome
    Adelaide Hills - SA
    Thanks for that PDF. I've saved it away in my directory of useful car things for future reference.
