Results 1 to 10 of 17
Thread: Are there emissions requirements for small engines?
    VIC
    A while ago I bought a brand new brush cutter for $60 from a very dubious source in the Trading Post. Naturally, it makes you wonder how one can make an engine for $60, let alone an entire brush cutter, and it was as good as a $60 brush cutter gets.
    So today I replaced it with a husky, it's half the weight, straight shaft, twice as powerful, free from vibrations, smooth and bloody quiet. I was thumbing through the manual and it has (no kidding) a catalytic converter and an EGR system. All on a 28cc motor that weighs 3 kg. Slight problem with the M and S lights flashing but I think the dealer will clear that up.
    Are there emissions requirements that these engines need to pass? Or are these emissions controls fitted just to be environmentally responsible?
    BTW if you need a brushcutter the husky is bloody great!
    Williams West Aust
    Hi
    I dont belive that the rules apply to us as yet.
    Its a machine built to meet much stricter euro standards,you benefit I guess from their standards.
    You will see it more as euro spec gear comes onto the market.
    Husquvarna make some really good stuff!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Oct 2006
    Wallumatta, NSW
    Despite the report quoted below identifying small power output engines as worse polluters than cars on a per hour basis, it does not appear that anything has been done about it. A similar story is also there about marine engines which, to the best of my knowledge, are also unregulated.
    From the Department of the Environment, Water, Heritage and the Arts (Feb 07):
    The United States, California, Canada and Europe regulate emissions from outdoor equipment - the USA has had these in place since 1997. There are no Australian regulations or standards that limit air pollutant emissions from engines used in outdoor garden equipment however as the majority of equipment sold in Australia is imported some do comply with emission standards applicable to the country of origin.
    Safety Bay
    It's the yanks that are causing the problem.In some states 2 strokes are banned and being the biggest consumer market they rule the roost. Pat
    Jun 2007
    Rodd Point, NSW
    After a $60 jobby the Husky would be a godsend. I'm upgrading all my machinery as it becomes available to 4-stroke, far less emissions I believe but they are heavier. Honda is doing good work with blowers, and they are indeed quieter engines.
    As far as I know, small engines do not have any legal emissions requirements. While the pollution (define that?) is certainly worse on a per unit power per hour basis than car engines, sometimes a lot worse, they are much smaller and with one exception (see below) they are usually used for only very restricted periods of time, so the actual amount of pollution is relatively small compared to cars.
    Where they are a significant problem is where large numbers of petrol (often 2-stroke) generators are used for long periods in large numbers in urban environments, usually where power is unreliable. They are supposed to be a major source of air pollution in many Asian cities.
    My experience of small motors is that the key design criteria are weight and cost, with everthing else secondary - from a user perspective my criteria would be more in the direction of cost, reliability and maintainability. Notice that emissions didn't get a mention - nor did fuel consumption!
    Brisbane, Inner East.
    As to manufacturing cost entioned in one of the earlier threads, how about this. I have a Chinese generator for which I paid $98 four years ago. I bought it in Winton. The Australian distributor is in Melbourne. So the gadget was made in China, shipped to Melbourne, then to Winton, and sold. I presume everyone in the supply chain has made a profit. What was the actual manufacturing cost? A$15 or $20? I put a vibratory hour meter on it when new and took it off in January this year after just shy of 600 trouble free hours. I use it for camping and have run lights and TV off it at home after losing power in a summer storm.If I ever have to buy another, I will buy the next bigger one which is four stroke, purely because the little two stroke does not have enough omph to start our domestic refrig-freezer.
    URSUSMAJOR
    Jun 2007
    Rodd Point, NSW
    Hi JDNSW, is your user perspective as a commercial operator or domestic? I find that using 2 stroke machines such as hedgers, blowers/vacs I cop the exhausts fumes quite a lot, particularly the hedger as it's at arms length in front of me. Other machines are better as the engine is usually behind the body. Give the emissions or at least safety some consideration.
    Dandenong Ranges - Victoria
    Quote Originally Posted by Ricey View Post
    My Honda 4 stroke brushcutter was expensive and not all that good.
    It is very well made, just not as good to use as the 2 stroke stuff I have always used.
    Harder to start.
    Heavier.
    Gutless.
    Suffers fuel starvation due to poor design (Honda replaces the fuel cap free if you complain, helps but doesn't fix it).
    Runs very hot and so is uncomfortably to use for longer periods.
    Hard to get the handles etc adjusted to get ergonomics right, not comfortable.
    It is quiet though, but given the need to buy another I would buy another 2 stroke.
    Not really separating commercial/domestic, but a would be pretty much the same, although if intended for consistent use, a commercial operation would have to look at other factors including expected life, cost of repairs, availability of spares, and similar.
    Safety is more a matter of the machinery that is connected to the motor rather than the motor itself, and varies from a very minor concern with, for example, a water pump, to a very major concern with, for example, a chainsaw (where there are very specific and rigid statutory requirements applying not only to the sale of new chainsaws but to the use or even the possession of old ones with safety deficiencies).
    I can't comment on the use of hedgers or blowers (one of the worst inventions of the modern era) as I have never used either, but I regularly use a chainsaw, water pump, generator, and (on the rare occasions it rains) a mower and brushcutter, so I have some experience of small motors. Emissions have rarely been noticeable in my experience, although I am quite prepared to believe that in some cases they would be a problem.
    One comment I would make is that I have a small Honda 2-stroke generator. By using a 100:1 oil mix it manages quite reasonable emissions - and compared to a four stroke of the same power it is light, maintenance free and cannot spill oil. And has always started first pull. (it was bought for the specific purpose of running the Engel, and does it well - it is almost silent, and runs for hours on the smell of an oily rag)
