Results 1 to 10 of 18
Thread: High Tensile Bolt Specifications
    I am after the SWL of various size high tensile bolts - after pull (tension) strength and shear (if used as a pin) strength.
    I did a google search but didn't come up with anything.
    Does anyone have a link to a site that provides shear and pull strength of these bolts.
    Oz
    99.87 MB
    When you calculate off that, don't forget that you'll be using the minor thread diameter and not the metric sizing.
    Slunnie
    I am not quite sure how that chart works - eg a 1.2" (approx cross section of 1 square inch) grade 9 bolt has a tensile strength of 150,000psi - so what does that mean in terms of actual strength - does this mean it could safetly hold something that weighs 150,000ibs or about 70 tons. So a bolt with a cross section of .5 square inch can only hold 35 tons. From this chart how do I work out shear strength?
    Thanks for the link
    Most of the bolts that you buy now come from China, and even though they are marked grade 5, are not actually high tensile. I have had a few failures when putting in new bolts. The only place to reliably buy bolts from is Caterpillar. Their bolts all meet the specification that they are meant to. Buying good materials and tools is becoming increasingly hard. Even Sidchrome is now made in China.
    Aaron.
    Thanks for the link
    Tensile strength is NOT safe working load! Tensile strength is the load at which the bolt will break. Safe working load is much less, how much less depends on a lot of factors such as the environment and the levels of acceleration and vibration expected. (typically perhaps 20% of tensile strength).
    WA
    Not quite - it is (AFAIK) the point at which the bolt will begin to plastically (permanently) deform. So in laymans terms, when the bolt will begin to stretch, but failure will occur shortly after.
    For (single) shear, tensile strength x 2/3 (0.66) will give you an approximate value.
    John (Bush65) is the expert on bolts and bolted joints though. Dig up some of his posts or send a PM if you want the best answer.
    Kiwiland
    Are you using metric or imperial bolts? The grades and markings are quite different.
    Typical metric markings
    grade 8.8 means 800MPa ultimate tensile strength (breaking load) and 80% of that (640MPa) yeild (when it starts to bend or stretch).
    Likewise grade 4.6 means 400MPa tensile strength and 240MPa yield. These are basically mild steel and as soft as they get.
    The highest tensile metric bolts you'll find are cap screws (allen key head), these are readily available in up to 14.9 and 12.9 depending on the size.
    Safe working limits depend entirely on the geometry of the joint you're using them in.
    Jul 2007
    Brisbane North
    mpa ?
    Kiwiland
    Quote Originally Posted by Aaron View Post
    mpa ?
    That's the unit used for stress. It's short for MegaPascal.
    A pascal is 1 N force per square meter. A MegaPascal is 1000,000 Newtons per square metre which works out at 1 Newton per square millimetre.
    1 kilogram weighs 9.81 Newtons (on earth).
