Results 1 to 4 of 4
Thread: Buying a secondhand 300Tdi
    Defender=1st Guest
    Anything in particular to look at when buying a secondhand 300tdi Defender ??
    Safety Bay
    How longs a piece of string?Check under the oil fill cap for sludge,colour of oil,colour of coolant, condition of gearbox oil,leaking steering box,how well it starts,the gearchange is notchy but should change well all the same.Does it look like it has been serviced by checking for greased uni's, driveshafts,good belts,hoses.Someone else's turn. Pat
    Feb 2005
    three big o ne
    complete service history
    timing belt....proof of when it was done last otherwise replace straight away for piece of mind
    main shaft, gearbox out put i think its called, simple to get inspect prior to purchase, remove the round plate on the back of the t-case and check the wear on the splines
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Check the rear chassis/crossmember for rust.
