Results 1 to 10 of 17
Thread: defender front drive shaft
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    on a 95 defender front drive shaft
    should the sliding spline be at the diff end or transfer shaft end.
    workshop manual doesnt show it :P
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    i know you know the disco one is at the t'case end. have no idea really
    Safe Travels
    harry
    Haynes 2017 Landrover 90, 110 & Defender 1983 to 1995 Diesel:-
    "8-2.8 a) Ensure that the propeller shaft is refitted with the sliding joint towards the front of the vehicle (nearest the front axle)."
    I install them with the slip joint closest to the Tcase mainly becuase it helps keep it out of the muck
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    so having it back to front wont create a **** load of vibrations at low revs?
    Yinnar South, Vic
    Quote Originally Posted by incisor View Post
    No
    I do as Blknight does, slip joint at the Tx end
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    bitchin.
    thats means it must b serious dam it...
    dave, when you home?
    Be interesting to know why they say to put it at the front.
    Logic would suggest that putting it at the back up out of the muck would be better, but then there is the other point - with the joint at the front, the join between the two parts is facing backwards, but if you put it at the back, the join is now facing forwards, where the muck is more likely to be forced in. Of course if you have an (undamaged) boot on it, this is less of a concern, either way.
    Williams West Aust
    I would have thought,without looking at any it needs to be where all the movement is,ie diff end.Thats why they have gaiters to protect the joint.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    bitchin.
    right now.
