Results 1 to 10 of 17
Thread: P38A Heater Core Replacement
    What have I been doing this weekend?
    Yinnar South, Vic
    HAHAHA
    I've done so many dash's doing wierd conversion, its not funny, its a very daunting task the first time, but you'll get used to it
    Southern Adelaide
    are you expecting many gubbins on the remount? looks like quite a task.
    Holy smoke
    And here was me chuffed just making the EAS unlock cable.
    Good luck with the rebuild.
    I'd offer to come over and help (and learn) if I was closer.
    2011 Range Rover Sport SDV6 Autobiography
    2004 Freelander TD4 SE
    1997 Range Rover 4.6 HSE
    1994 Range Rover Vogue
    It's all in - and now it has to come out again. The brand new heater core from Land Rover leaks more than the old one did and it's not the heater O-rings.
    Sep 2006
    Martinsville, gateway to the Watagans!
    My suggestion Ron...take whatever core ya get, to a radiator place and get it pressure tested before installation!
    And trust me, that one doesn't look -too- bad. I've got pretty good at heater cores in my time XD, considering I've done...a few put it that way. I even did the Rocky's, and it hasn't gone back in . Because it's such a pain.
    The evaporator looks fun to do on those too . Call me stupid, but is it not possible to unbolt the entire metal brace with crash pad and dash panels attached? I've never done a p38 before, but that's generally how it works.
    And Ron, what's all that icky wiring hanging around? You ought to be ashamed of yourself!
    Yes, one can remove the whole fascia and that's the recommended method. Dunno if it is any easier. I am replacing the top of the dash with one I bought from Melbourne last year.
    Yes. the white temporary wiring. All the rest is factory.
    Sep 2006
    I always knew RR secretly wanted to make their wiring look like a nightmare. I take it back, you shouldn't be ashamed of yourself. They should be ashamed of themselves!
    So is it coming back out today?
    Undecided on whether to pull it today or tomorrow. I've not got the will at the moment.
    Yinnar South, Vic
    Bad apprentice Ron, you should know, you always test the goods before install, even when new
    Very easy to pressure test yourself with an air compressor with regulator fitted
