i have lost high beam in my series 1 disco i can still flash them but they will but can not change to high from low is there a fuse or relay to look at first
cheers Al
Or you could try cleaning up the contacts with a "points file".
My rangie had the un-nerving habit of dropping power to the headlights in High beam only, usually around midnight while driving home from work. Fortunately, low still worked.
I pulled out the stalk, buffed up the contacts and she's been great for the last couple of years.![]()
use a dead credit card instead of a points file or it'll happen again but faster.
takes longer to clean up properly with the smoothish plastic of a credit card but it seems to work better for me in the long run.
