Results 1 to 10 of 11
Thread: D2 bonnet scoop
    Northern Beaches Sydney NSW
    D2 bonnet scoop
    hi - just wondering about placing a bonnet scoop out of a nissan or holden onto the bonnet of my S2. question is i know they either bolt, rivet or glue scoop down but are they holes drilled in the scoop to allow air to flow into the engine bay. Im after the look and thinking of placing two on the bonnet. would i need to drill holes in the bonnet and how big a hole do i need to create to allow the air flow. series of smaller holes or one big hole. have never looked under the nissan scoop so not sure. thx
    sunny Hobart
    come on guys, someone must have done this before
    Ferntree Gully, Vic
    What do you really want a bonnet scoop for on a Disco?
    May 2003
    On The Road
    if its for looks,, it'll have to be "hole to the front"
    which will swallow water VERY well,,
    however, the scoop when faced "hole to the screen" will extract hot air very well,,
    didnt BB do this a while back?
    99.87 MB
    As I understand it... you want to have bonnet scoops on the bonnet... but no holes through the bonnet.
    In all honesty.....
    I'd start with 22" rims and spinners.
    Slunnie
    May 2003
    On The Road
    and bigger aeriels,,
    Brisbane,some of the time.
    saw a disco in 4wd monthly(now action) cant remember which edition but someone may know.
    it had a gu pooootrol one on it
    did look
    cheers paul when are our sighatures coming back?
    Williams West Aust
    BigBugga did it to his D1 using a GU scoop.His idea was to improve underbonnet temps being V8 powered and living in the Pilbara(one of the hotter parts of Aust)
    It did look good.
    I put one on our Triton when we had it,it was a GU copy from The Spoiler Factory(Armadale WA).It too looked great,and was for a purpose,I had fitted a turbo intercooled(top mount intercooler) motor from a newer Pajahero.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    mcrover Guest
    My suggestion and I stress this is only a suggestion is as follows.......
    Go out to your Disco and have a look at how nice it looks as standard.
    Get underneith and notice that it has a high/low transfercase and live axels front and rear and maybe come to the conclusion that it should be used off road.
    The realise that if you cut holes in the bonnet may limit it's 4wding potential in certain situations.
    Then if still convinced that you need a vehical with bonnet scoops then you take it to your local Nissan dealer and trade down to a Pootrol with a nice shinny new scoop.
    Just a suggestion
    yerrr
    i dont realy get it....scoop to the front it will look like a japthing
    scoop to the rear it will look like an a9x torana
    no scoop at all a beautifull piece of land rover engineering
    paul
