Thread: TD5: Engine oil in inlet manifold???
    Belfast, Northern Ireland
    Hi
    I've got a year 2000 TD5 with 119K miles on it. I took the hose off the inlet manifold, and could see some engine oil lying in the entrance to the manifold. There was also engine oil smeared round the inside of the hose with some lying in the bottom of the hose that dribbled out.
    There was also some engine oil on the map sensor which I cleaned off.
    Is it normal to have engine oil in the hose and inlet manifold?
    Maybe there is some other issue developing with the turbo maybe?
    At least I know now my intercooler needs a good clean.
    Andy
    more than likely its your crankcase ventilation system.
    Thanks Dave
    Is my Crankcase ventilaition system acting normally or do I need to have a look at it?
    Andy
    NSW far north coast
    It's normal on any turbo diesel from ring blow by.
    sconded its acting normally but in the interests of saving your intercooler turbo and valves you might want to check out the provent threads.
    Ok Guys,
    Thanks for the info.
    Andy
    Ellendale Tasmania.
    Quote Originally Posted by andymach23 View Post
    Hi
    Andy
    Take your inlet manifold off and clean it too, i had mine done when the head gasket was done, my mechanic reckoned that there was that much gunk in there, it was 5mm to 8mm deep
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
