Gday,
A photo would be good, also what is the fix for this, did you discuss a fix?
tony
I have just had my 07 Fender in at Ivan Clarke in Wodonga for a final inspection check prior to heading off to the Kimberlys. One of the issues that Ivan found was that the bottom turbo hose had been rubbing against the steering shaft knuckle. I would suggest that you should check this, it is visible from underneath the car.
Gday,
tony
