Results 1 to 10 of 12
Thread: My Disco hates water - help!
    Oct 2007
    Hey guys
    Whenever I hit a decent puddle to splash into the engine bay or get about axle deep... disco spits it and loses power... turns off... takes a while to get going then runs like crap... i get alot of clunking and banging under the car too - sounds like mud flicking off along the highway at speed but it isnt!
    Now, i know its water hitting something and cutting the electrics, but I though water didn't conduct enough to short a system? Alos, my mates disco with a higher coil than mine (I have dual battery set up in the way) doesn;t suffer anywhere near as much. I know the clunks are little misfires too.
    The dizzy, maf and air filter look dry but just dont know why it wont burn cleanly... also, what is likely to cut power like that?
    I have the coil and amplifyer module under the air filter...
    anyone sorted this out before?
    May 2008
    Manly NSW
    Gee thats a doozie mate, have you spoken to LR and how old is the car?
    Oct 2007
    its a 97 model and havent spoken to landrover or mechanic yet... i have found no one at a landrover dealer helpful...
    Colac foot of the otways
    Not enough info.What car is it
    I will assume d1 V8 as you mension coil
    what fans are you running
    Is the cowl on
    Sounds like steam hitting the dizzy and leads to me,It may not look wet but it only needs a little bit of moisture to make it start missing.
    If you have the cowl off the fan will pick up water and throw up and create steam(will do this with cowl on to lesser degree)
    If you have thermo fans turn them off before going through water.
    There is probably other things and sure people will steer you in the right direction.Cheers Brett
    Oct 2007
    oki doki
    97 series one 3.9 with ABS, hence coil and amplifier unit is mounted below the air box (LHS). cowl is on, thermos never work and the vicous fan always spinning.
    Today I went through a puddle where the water was half way up right door but dry left side and was fine. It suggests to me that its the coil and associated wiring. can water get in under dizzy and stuff it that way? It dries quick, site on edge of puddle back off and let it iddle so it regains composure, then after a few minutes dries off!!!
    maybe you guys could suggest some tests, I will do the haynes test from the book this weekend (voltage measure) but no other ideas...
    its a new coil as I thought the old was just ruined but same problem.
    i know leads arcing are a common problem. I have seen mine jumping at idle sometimes... mostly after my last fraser trip
    mike 90 RR Guest
    Quote Originally Posted by braddles1 View Post
    oki doki
    Q .. What type of new coil did you install ???
    Something to try ...
    Try a new set of leads // A good set, not cheapest ... old ones end up letting water in???
    I use Champion (gas) leads ...
    I used other lead sets and burn't them out in 4 weeks ....
    Also give the leads / dizzy cap / coil / amplifier .... a spray (can) of "Innox" or Lanolin based grease (something that takes heat & won't wash off) .... Create a barrier between water & parts
    Let us know if it works
    Mike
    Jul 2007
    Maitland NSW
    Another thing that can cause this is if you sprint through a deep enough puddle of water at speed. The cool of the water spraying on your distributor cap causes condensation on the inside of the distributor cap (like on the windscreen of your car when it rains. In this case the only thing I think you can really do is spray it inside with an anti fog or just remove the cap and wipe it out with tissues or similar
    Oct 2007
    hey guys - thanks for the suggestions but haven't had time to try them out this weekend... wen i do i will leave some feedback...
    problem is i often cant get out of the water... car dies dead... so cant just dry it out and keep going all that easily...
    will let you know how i go...
    thanks
    mcrover Guest
    You have a choice here,
    One cheap,
    One expensive.
    The one I would take is the expensive one.........Go buy a diesel.
    But the cheap one is really really simple.
    WD40, CRC, Silicone spray, Rust tech, Lanolin spray, Rustoff or any sort of penetrating/water surpressing sprays.
    Liberally spray on any electrical componants and stop worrying.
    Buy the way, if you want help it makes it easier if you put in your post what vehical your talking about as well as your location so people can point you in the right direction if it is more than what you can handle to repair.
    mcrover Guest
    thanks
    Silicone grease on the dizzy cap seal and on the coil connections etc will also help.
    Ive also seen people use battery terminal spray to seal up petrol engines from water ingress in their electrical systems and there are a couple of good clear sprays around these days which look a bit better than blue or yellow painted all over the engine bay.
