Results 1 to 8 of 8
Thread: Axle Stand type thing wanted... but from where...
    Oct 2006
    kinross, Perth, WA
    Hi Guys
    I am after an axle stand style stand for lifting the draw bar up on the boat trailer. the Jockey wheel gets a bit bendy at full extension so need to support it a bit better for when im working on it (read spending money on it)
    so im after a stand that is similar to an axle stand, but has a screw type adjustment on it rather than pins or ratchets..... i also need a lot of lift! if i could get a 350mm - 600mm range that would do me... (the boats is on a drive sloping the wrong way)
    any ideas where i could get one? perth or mail order is fine
    Steve
    Mar 2007
    South Arm, Tasmania
    Steve,
    What you want is an "ALKO" heavy duty adjustable "Jockey Wheel Jack Stand". They replace the jockey wheel on your trailer, have a base plate instead of the wheel, and a wind-up jacking handle. You can get them in a range of lengths / heights.
    Should be able to get them through Trailer Parts WA -
    Bayswater 9279 5777
    O'Connor 9314 2222
    Wangara 9302 2800
    Hope this helps. Cheers ............... BM
    Cheers .........
    BMKAL
    Oct 2006
    kinross, Perth, WA
    Thanks for that BM, i looked at those, unfortunately i cant use them as they dont swing up, and the draw bar sits too low to have just a normal type lift up one. The jockey wheel i have is a 10" swing up type...
    i will have another look tho.. as maybe i could run both on there...
    another bit of info.. its a twin axle trailer and i cannot lift the drawbar. The noseweight is pretty high... otherwise i'd be picking it up and dumping it on a stand..
    Steve
    Mar 2007
    South Arm, Tasmania
    No worries Steve. Another option might be to install a drop down corner jack (as fitted under the corners of camper trailers / caravans) under your drawbar. Most of these fold up flat when not in use, and there are various designs available which will drop down onto the ground, and then you can wind the legs down further to get the lift you need.
    The one I'd look at is the BIG FOOT 590MM ALKO Part no: AS-2177. Any decent trailer parts supplier should be able to get these. Have a look at
    Caravan,RV,Marine and Motorhome parts and accessories online, rollout awnings
    Another couple of places to look are
    Caravan and Trailer Jacks
    RV - 00 RV Accessories
    Cheers .........
    BMKAL
    I was at supercheap the other day and they were selling axle stands with screw thread adjustment, brand was Stanfred or similar two-name combination.
    I have a pair, same brand that I bought a dozen years ago, still going strong.
    I saw that the new ones come with a grease nipple to lubricate the threads.
    Look the goods.
    Simon
    Singapore via Melbourne
    just nick an acro prop from someones scaffolding
    preferrably when not in use!!
    secondary benefit, if you are working under a roof and mount the prop between floor and ceiling, it can also prevent the boat tipping up if all the weight is in the back. I'd mount it in the jockey wheel's clamp too for extra security.
    Invermay Tasmania
    Steve give Camec a ring 9351 0000 they will have it
    Unit 1, 175 Welshpool Road
    Adam
    Oct 2006
    kinross, Perth, WA
    Quote Originally Posted by EchiDna View Post
    i did think about that... but i'm not working between floor and ceiling! the boat is about 3m height and the garage is only 2.2 wish i could keep it under cover.. wouldnt need the prop then
    thanks for the number agro.. will call them and find out..
    thanks also for the links BM.. will chekc them out too..
    and finally thank abaddonxi i'll also check supercheap out too..
    you are a helpful bunch!
    Steve
