Results 1 to 10 of 11
Thread: D2 owners with Milford cargo barrier please read.
    Apr 2007
    Dayboro
    I got a Milford cargo barrier fitted last week in my wife's 03 Disco. Got it home and had a look over it to see how it moves into the second position ect, then found two large semi circle cuts in the carpet under the seat. They don't appear to be associated with the install of the cargo barrier.
    Was hoping some other D2 owners with cargo barriers could check thiers for me to see if they also have the cuts. I've also noticed they've cut around the four cargo tie down points. Check out the pics to see what I mean.
    No I don't have this. Mine was one of the first 03's to get a barrier fitted.
    Cambewarra, NSW
    Hi, my 02 has a milford barrier that the previous owner had fitted. It does not have any cuts beside the tie downs. It does however have a "U" shaped cut over each body mounting bolt under the seats, just forward of the barrier, look like they were done with a stanley knife.. Not sure why but maybe there was a service bulletin calling on the tightness of the bolts to be checked.
    There are also cutouts in the carpet under the seat where the forward barrier mounting plates are fitted.
    Brisbane,some of the time.
    mines an 04 & its got the cutouts under the seats but there are none near the hold down rings.i also have the barrier fitted but i think it has nothing to do with the cut outs.cut outs are pretty neat i pressume done by lr....possibly done in factory
    The cuts are normal as in some places the carpet and padding are almost 1.5" deep. It is necessary to get to the floor panel to drill the holes and clean / treat them for anti corrosion.
    I fitted mine on my 2000 model and was loathe to do it.
    Land Rover - The leader in chasis rust protection with leading edge oil application system.
    2000 Discovery TD5 - ACE. 2" Lift and Bloody big lights
    2016 Discovery D4 SDV6 HSE ARB Bar, lights and winch. Wow
    99.87 MB
    I had never noticed them, but I have them all.
    Slunnie
    Apr 2007
    Dayboro
    Thanks guys. If others have them then I will try to ignore them.
    Highlands NSW
    Yep have same.. spotted only the other day.
    2010 110 Crew Cab Deefa
    Mittagong NSW 2575
    Out of interest, why are you worried about the cuts?
    Apr 2007
    Dayboro
    Quote Originally Posted by dobbo View Post
    Thought it may have been a mistake by the installers, and that it would be an ingress point for sand/dirt/moisture. Just being pedantic about our newly acquired car I guess, shouldn't really be a problem.
