Originally Posted by
John W
I tried engaging it while the engine is running and that works fine so thanks but would be nice to be able to leave the CDL in during an expedition and not have to worry about it. Just a pity that cutting the wire did not work for me.
This is from the Ashcrofts Transmissions web page for CDL installation in the DII
To finish off the job...
1) Disconnect the battery. Unscrew the four hex screws in the glove box hinges. Reach round the side of the glove box with each hand and pull the closing mechanism upwards. Slide the glove box out
2) Pull out the 3 push-studs on the black cardboard panel underneath the glovebox, and undo the screw stud at the back. Remove the panel.
3) Near the outer side of the gap behind the glove box, you will see 2 or 3 ECUs, depending on whether you have ACE, I think. The SLABS ECU is the centre of the three, or the outside of the two. It has 5 black connector blocks underneath. Remove the centre block of the five from underneath the ECU.
4) Look for the black & blue wire running to pin 9 of the connector block, which is the central pin on the lower row, i.e. the row furthest from the retaining clips. At this point, make sure you have the right connector, and the right pin!
5) Cut this black & blue wire & tape off the ends. (Give enough space to solder it back together if you find out you have cut the wrong one...) Reconnect the connector. Replace the panel and the glovebox. Reconnect the battery.
Please note :
This is not needed for 2003 on (facelift) models as the ECU has been reprogrammed to take care of NOT disabling traction control/ABS when CDL in engaged, when ignition is switched on.
To test: engage the CDL and start the car up. The CDL light should be lit, but the ABS/TC lights should not be lit up. This is correct - it means that the SLABS ECU is not disabling ABS/TC when you start the car up with the diff lock engaged
We would like to express our thanks to Mr David French of Surrey for providing these informative installation instructions for us
Baz.
Cheers Baz.
2007 BMW R1200GS
