Results 1 to 10 of 23
Thread: Re-Upholstering a Roof Lining
    Jock The Rock Guest
    Gaday
    i have a 110 2 door defender, the bloke who owned it before me went on some trips in the outback and so on so it is pretty dirty and sags like nothin else. i was wondering i can fix the sag myself but today i went in for a quote to have it re upholstered (just the roof lining i took it out myself).
    The bloke said $160
    Would you say that is a bit steep just to put some new fabric on an almost flat surface?
    i may end up just buyin the material and try doin it myself?
    Thanks for ur help and advice
    Jock
    Canberra, Australia
    A couple of years ago I redid my RR headlining, using 3M spray on contact adhesive, and a textured/knitted fawn coloured fabric. May have cost me $60. My advice would be to use plenty of glue.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Don't waste your time doing it yourself. It will fall off again as the foam backing is deteriorating.
    Narre Warren South
    I went through this a few years ago when the headlining on my Defender started to sag. I remember all the useful comments like 'hold it up with drawing pins', 'put a hat holder in as that will hold it in place', 'cut slits and inject some glue behind it', 'fit an overhead console' .....
    The original lining is a PVC type of material which is great because it can be washed but every single motor trimmer I spoke to could not offer a replacement material so it meant a complete new headlining (from memory just one section was over $1,000 from LR). So it had to be replaced with a conventional headlining material.
    As p38arover commented it's the foam backing which is breaking down. The headlining material has a very thin layer of foam on the back and it is the foam that is glued to the headlining board. With time/heat etc. the foam breaks down and you get a saggy lining.
    Mine cost about $130 2 years ago but I removed & refitted the boards myself (and cleaned off all the foam residue) so the price quoted sounds about right. While the boards were out I reinforced them over the Alpine windows because they were starting to sag.
    If you do it yourself you need to be careful with the gluing process. If you push the material down too hard the glue squeezes through the foam so the material bonds through the foam and the surface ends up with a 'dent' in it which is impossible to get out. You need to spray glue the board and very carefully smooth the material into place, then wait a day or so to ensure the glue is completely dry before re-installing the headlining (otherwise you put dents in as you install it !).
    Hope this helps.....
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    NSW , Pennant Hills
    Fibre Glass the roof side of Foam-Backing first and then Glue the Fabric to the Foam lining , I have had great success with this . had done it 5 years ago and nothing has sagged .. and rooflining looks good too ,the process is time consuming but the end result is definitely worth it.
    Jock The Rock Guest
    Quote Originally Posted by gromit View Post
    Colin
    thanks mate
    mine is only a 2 door troop carrier so only the part above the driver is lined with fabric rather than the whole roof.
    thats why i thought it was a bit steep?
    Jock
    Jock The Rock Guest
    i got it all done cost $130 cash but was well spent i reckon. had it done in stuff a bit like carpet so the foam backing doesnt rot and droop, also its possible to just vacuum the stuff which is good
    ill post some pics up tomorrow personally i think looks pretty good
    Jock
    Jock The Rock Guest
    here goes. also to fix the problem of the sag in the middle of the lining, i drilled up through the rib in the roof and put some of the upholestry screws (dunno wot they are called ) in holds it up pretty well i reckon.
    does anyone know how to post the pics up so that u dont have to click on them to see full size. so the come out in full size in the post?
    Jock
    Hey guys
    I did my Disco like Jock.
    Looks ok with all the plugs (get them form Repco etc).
    people laugh at it but I'm a tight **** and I'm the only one that has to look at it anyway.
    No joke Landrover must have used Perkins Past on it.(only old dudes will know what that is.)
    Harry
    Disco 97 TDI
    May 2008
    cairns
    roof linings are for girls rip it out put it in the bin and paint the ceiling black .heaps more room and less too worry about and the rain is not that loud hitting the roof any way
