bloody hell woman..
hope it works out in your favour!
Dealer called us today.....as some of you may know car went in wrongly for its 10,000k service
only to be informed our car is STUFFED.....
WHY? ........water in the fuel.
they said they have never seen this amount of water in the fuel before and they are actually supprised that the car managed to continue running!!!!
we have been quoted off the cuff of 6 and a half grand!! that they said may possibly not be covered by insurance.
the car needs everthing replacing!!!
bloody hell woman..
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
Any chance of tracing back to where you got your fuel?
And what about the water dash light on the bottom of the filter?
Surely you shouldn't have to carry the can.
DB, Ouch!! I bet that makes one feel happy... NOT!!
Disco Owner, how can a dealer warranty cover damage caused by the fuel the owner puts into it? In my understanding, warranties are against faulty manufacturing, not misuse - even if that misuse is completely unintentional as in the case of water in the fuel. This is what you buy comprehensive insurance is for!
that said, if there was a way in which it was found that it was faulty LR assembly (i.e. fuel level sender is loose and any road spray or water flowing over the fuel tank runs into the tank) then you might have a warranty claim...
DB, if you bought all your fuel from one location, then the reciepts and mileage logbook might come in handy for a small claims tribunal claim against the supplier of the fuel - you cannot be alone in that situation, there should be others with stuffed motors from the same source.
Hmm - sorry to hear! Sounds very strange though...
It should take quite a bit of water before you get any near your pump/injectors.
Any more detail on what exactly is damaged???
There was a lot of water in fuel issues a few months ago.. one of the majors was responsible.
Heard of a few Toyotas having issues. My neighbour put her RAv/Highlander whatever it is into the dealer for rough running, they didn't pick the water, & sent her on her way. 2nd time they did when the engine died & needed replacing. Warranty covered the dealer error .
Max P
Now that raises an interesting point. If you're silly enough to run off the road and into a tree, where it's entirely your fault, and you do $6K+ damage to the engine/drivetrain or any other bit, then you're covered.
Could it not also be successfully argued that you're also covered in this type of no fault scenario ??
 Fossicker
						Fossicker
						DB,
Any chance this water can be traced back to the last time you fueled up. I know that from a dealers point of veiw that contaminated fuel in these common rail systems requirers the replacement of everything. However I have seen contaminated systems cleaned out as long as the contamination has not reached the h/p pump and injectors. Was the engine running well when it went in for service? Is the contamination water, collect a sample.
Does the new defender have a water warning light on the dash to indicate water in the fuel? Did this light work?
