Results 1 to 10 of 14
Thread: Chopping Rear quarter panels??
    Jun 2008
    Cedar Grove
    Hi everyone. I was hoping someone might be able to tell how much it would be to get the rear quarter panels cut so my tyres dont rub. I have a 2" suspension lift and running 31" Mud tyres and I'm in Brisbane. Any ideas would be greatly appreciated. Thanks in advance.
    Jodie
    Dalby
    There is no need to pay someone for that. Takes about 2 mins to either bend it or cut the offending material out. It is not something you can see from standing beside the vehicle. It is underneath.
    I bent mine to begin with but they still scrubbed so I attacked it with some cutters when at the Springs 4wd Park.
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    I'm about to do this to!
    Just looking at it all it would take is a cut with the angle grinder and make shore you tape up around where your cutting so the paint doesn't blister.
    CHEERS TIM.
    Foot of the Otways
    Hi Jodie , If you are unsure about cutting the guards yourself maybe a member up that way could do it for you . pretty simple task if you can use a grinder .
    Dalby
    She doesn't need to do the full cut. She is only going to fit 31s. She only needs to bend/trim the folded under bit.
    Rye or cranbourne
    i done my quarters a while ago now but i just ran some tape along the panal then cut with grinder with a thin cutting disc then just folded the rough edges around and sprayed with some touch up paint,
    here is a couple pics
    SA, Newton
    Cool Pics
    Anyone with othere pics of cuts, around doors etc
    Rye or cranbourne
    the doors or camal cut as it is called are best left to professionals to do and is not cheap, getting mine done soon and flares added but there is another thread in discovery called show me your camal cut
    cheers mick
    VIC
    Quote Originally Posted by mickashay View Post
    cheers mick
    The camel cut is only the rearmost section of the rear wheel arch
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by B92 8NW View Post
    Yep and where Mick cut his is unnecessary unless you plan on fitting a tube rear bar or you have already trashed the rear 1/4's. Thin cutting disc on an angle grinder is the best way and takes all of 2mins each side, just measure 2" back from bottom rear of guard and run a line of masking tape up till it meets where the rubber strip meets the arch and cut.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
