Results 1 to 2 of 2
Thread: SLS - Disco 2003-2004
    disco_2008 Guest
    Hi
    Just wondering if SLS was a standard feature on all 2003-2004 Discos?
    And how does it function. Does it increase the rear ground clearance, is it a button on the dash?
    May 2003
    On The Road
    SLS was available from inception on the D2,,
    The 7 seat model came with SLS as standard,, you could also specify it as an option on the 5 seaters.
    It works seamlessly, no driver input is required as the system adjusts the ride height to suit all loads.
    There is an Extended Ride Height button on the dash that lifts the rear to give the same departure angle as the D1.
