Results 1 to 2 of 2
Thread: sunday's tlc
    Feb 2005
    sunday's tlc
    after reading inc post
    ran the rig over the pit today
    changed
    engine oil and filter
    fuel filter
    air filter
    checked all fluid levels
    greased drive shafts, pitman arm and pto
    adjusted handbrake
    fitted new nylocks to the rear output flange
    when to change the t-case rear output cause i thought it was leaking again, only to find the bit of oil around this area was the leak from the pto drive that i knew was there.....
    looked towards the drivers side rear wheel and noticed the oil on the back of the rig was coming from hub seal that i only replaced a few weeks ago
    will trade the rear output seal for another hub seal and follow everybody advise and knock it all the way in....getting sick of changing this hub seal, i checked the breather and it was clear, left the filler plug out while oi operated the air locker and could not hear and leaks
    i put a grease nipple in the pitman arm ball joint when i fitted it last time, bloody hard to pump grease in and the rubber boot keeps popping off, will see if a zip can hold it in place
    just got to address the oil leaks from the rocker cover and vaccum pump thingy
    my fuel lift pump does not work but the rig seems to bleed itself after changing the fuel filter....well a bit of coughing and spluttering and she is away, is this alright or should i fit a new one?
    umm, better start a service maintenance list for my planned high country trip next year
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    yep, you get on an angle and it aint so pleasent...
    ask me how i know
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
