Results 1 to 10 of 23
Thread: part numbers
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    part numbers
    anyone know the LR part numbers for 85 county 4bd1-T with LT85
    clutch plate
    pressure plate
    throw out bearing
    pilot bush/bearing
    front springs
    rear springs
    front shocks
    rear shocks
    2 prong fuel cap
    i cant find them in anything i own...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    WA
    Quote Originally Posted by incisor View Post
    clutch plate
    pressure plate
    throw out bearing
    pilot bush/bearing
    front springs
    rear springs
    front shocks
    rear shocks
    2 prong fuel cap
    Don't have the PN's, but IME, most parts places will have listings for a Land Rover (county) 3.9 Diesel 5 speed.
    No such thing as a factory 4BD1T county.
    I have king springs in mine, I am happy with them. PNs are floating around here somewhere I think.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    this thing has kings under it but they are way to stiff so i 'd say the are heavier than usual..
    the clutch would be the same i would think (hope).
    WA
    King springs make 2 different fronts for 110s. Standard height and 2" raised.
    KRRS-02 and KRRR-02 respectively.
    http://www.kingsprings.com/kings_master_catalogue.pdf
    I have the 2" lifted srpings all round. I am happy with them. Front is a bit stiff, but mine is a touring vehicle, and by the time I bolt a winch on it will be fine.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    will see if i can find a number on these things they look quite new so hopefully something is still there..
    Jan 2008
    Sunshine Coast, QLD
    Fuel cap: Whats this cap from...
    Had me stumped, British offroad had no idea also. I guessed its a custom jobbie from the guy who did the conversion.
    Hay Point
    Hi mate, I can help you with a few of these
    5 Speed clutch plate......AYG3463 (thats the normal one-dont think they make a special one for the turbo motor)
    Turbo motor pressure plate...8970317592
    Throwout (same as 4 speed).AYG3339
    Input shaft bush assembly....AYG320
    Regards.......................................Bria n
    Hay Point
    Found another one..2 lug fuel cap ....504655
    regards....Brian
    Sandstone Point Qld
    Hay Point
    That one on EBAY is a 4 speed clutch kit. The clutch plate is for a 4 speed with turbo motor AYG3616 and the pressure plate is for a non turbo motor-Part No.5312200240.Throwout bearing is standard....Regards..Brian
