Sikaflex is your friend!!![]()
Does anyone have a good suggestion to seal up those little gaps in the Door seals. There are 2 cut out sections on each door at floor level and these are the only places that let in water while I was wading the rivers up Cape York recently? Why do they have those cut outs anyway? It is a 1999 model.
What stopped me was the thought that silicon may be a bit lumpy and distort the seal on closing, but will give it a go, so thanks.
Yep, I may. Try using the rubber piping that goes around a flyscreen door. Insert it through the door seal rubber & silicon it up. Not sure if you need to feed it right through the whole door seal, I did only about 5cm where the gap is. BTW I no longer go in dams / rivers so can't vouch it works.
I sealed mine up with RTV silicone sealant as well , works a treat
I still cannot understand why they are there either, unless its a place to let water out should it come in elsewhere![]()
Cheers Baz.
2007 BMW R1200GS
Sounds like a feasable explanation, how ever, surely its not rocket science to put the "splits" higher up ? even at the top ? especially on a vehicle that "might" go for a swim once or twice in its life.
On the flip side, the "sealing" of the cabin on ANY Land Rover is not that good to build up that much pressure when shutting a door, the air vents are a big "hole" to the outside for a start.....
definately a strange one these factoy "splits".
Someone once told me the slits are there to let water in so your truck won't float.![]()
97 D1 V8 SE manual - loud & locked - RPI Optimax & some toys
09 D3 HSE
Sold and missed: 03 D2a V8 auto
LROCV member
I love it when a plan comes together!
John "Hannibal" Smith
G'day all,
It's about 12 months on and I was wondering how succesfull the sealing has been.
I assume the slits are there to stop them lifting in the bottom corners.
Mine need to be done to the stop dust ect.(read water) geting in.
Is a windscreen sealent better as it stays flexible?
Whats worked for you ?
TIA and cheers.
I did the flyscreen tubing- RTV trick as well. Works really well, and you can barely notice it. The door is slightly harder to close, but it is barely noticeable. I've never been stationary in deep water for long enough to see if they do seal all the well, and hopefully that will never happen. Water just ruins a carpet interior.
Discovery RockSliders
https://www.aulro.com/afvb/the-veran...ies-1-2-a.html
