Thread: Series 1 Gulf spec
    Jun 2008
    Suburban Canberra
    Question Series 1 Gulf spec
    Hi,
    How can I tell if my D1 is Gulf Spec, and what are the differances to other specs?
    streaky Guest
    There will be a silver/white sticker under the bonnet on the slam panel. It says "GULF SPEC- do not remove this label".
    Does your Discovery have any other identifications ie. FXi etc?
    Obviously it will be a left hand drive. Later Discos had the Gulf Campaign air conditioning and cooling upgrade done. larger fan, bigger rad, higher output alternator and the now infamous 'Saudi Spec' Grill as it's been nick named.
    What makes you ask?
    Thx.
    S
    Jul 2008
    The pathetic looking chicken wire grill should be the big giveaway.
    May 2003
    On The Road
    Quote Originally Posted by westonben View Post
    you cant drop a clanger like that and not back it up with a PIC,,,,
    Jun 2008
    Suburban Canberra
    Thanks Streaky,
    I'm just trying to expand my Land rover knowladge and understand what other posts are talking about.
    Jul 2008
    I'll get a photo and post. I think a lot of time went into the design......
    streaky Guest
    A Lot more time than you'd think actually. My Discovery was one of the early testing cars for the Gulf Campaigne grill. Designed by Patrick Fay (the in-market testing manager for Land Rover Middle East) lessons learnt from this up-grade were later utterlised in both the series II Disco's and the P38 Rangies production models.
    The upgrades needed are to change the radiator to a larger capacity one, bigger twin fans, larger output 120ACR alternator, alot of additional plastic panels that fit behind the grill to divert 100% of the incoming air through the radiator, longer serpentine belt, hairbrush oil cooler for the transmission.
    I ran mine for a few months under hot weather and desert conditions before providing feedback to Land Rover in Saudi. It was a free upgrade to anyone with a late model 300 series Discovery.
    The grills are quite rare now and many people want them for their looks alone without even having the other benefits of the entire kit.
    Regards.
    S.
    Jul 2008
    We must be talking about different grills. Mine is a piece of chicken wire which hasn't stood the test of time very well. Patrick Fay must have been a contractor, and convinced his boss he'd spent ages on it, just to get some extra hours on his timesheet.
    Must do the photo tonight...
    Jul 2008
    Not my finest photographic moment, but better late than never...
    streaky Guest
    Thats a genuine GULF Spec grill....I note from your registration that the vehicle is from Qatar. I can also see the 50th Aniversary badge which makes it an original grill. The aftermarket grills didn't have this.
    The addition of the grill doesn't mean that your vehicle couldn't have been a grey import from Europe...but see if there are two plastic plates screwed down in front of the head lights....these were also part of the kit (amoungst alot of other mods to the A/C and airflow).
    Parick has left Land Rover division now.....he took the same job title with Aston Martin and spends most of his time cruising the highways testing air conditioning units, hot weather testing of other components etc.
