Results 1 to 8 of 8
Thread: 12v 4bd1 starter p/n
    Seaford Vic
    Hi,
    Can anyone tell me the correct part number for a 12v 3 bolt starter motor.
    Westy
    Check this thread
    Apr 2007
    Sydney city
    Hi Westy,
    See specifically this post from that thread.
    I had an auto electrician stick a new motor into my existing case. Works a treat.
    SW of Geelong
    Quote Originally Posted by Ben View Post
    The case (reduction box) part is the important bit. The electric motor is reasonably common. I had the motor replaced on mine last year. It came off a Toyota starter and bolted straight on.
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Hay Point
    Hi Westy, Heres a couple of numbers that may help you out. Ashdown electrical (wholesalers) have a 12V 3 bolt starter P/N 01-76561. Ingram electrical also have one P/N 843843 and then there is the Army type mitsubishi unit Isuzu part no 8944634730 which I reckon is the best unit if you can get hold of one. Regards....Brian
    130 ambulance Guest
    isuzu 3 bolt 12V starter
    Hi westy
    My starter is out of an Canadian Isuzu NPR Truck but it has three bolts and is 12v My part# is 5811001692 and the tag says Isuzu I'll e mail you some photos. It looks to be the same as the one in a landy. I hope this helps.
    Regards, Justin
    Here's an edit... I just Checked with a supplier in the U.S MY P/N HAS BEEN SUPERSEDED BY PART# 8973580621. It looks like you have a load of different p/n to check on. I have also sent the pictures of my starter to your e mail...Cheers
    Seaford Vic
    Thanks guys
    Here is the tag on my starter
    Looks OK, although the numbers are slightly different to those posted, probably just a different model or year or superceeded to another number.
    I know its a bit scratched but look closely it does state "12V" and it is a 3 bolt unit
    Does anybody know what model/year its off? I bought the engine from a farmer in Tassie who said it was in a stage 1
    Cheers westy
    Contact PJL diesel electric in Perth. Ask for Cameron. These guys do nothing but electrics for diesel applications. They can cross reference just about anything and Cameron is a wizard!
    (08) 9258 7555
