Results 1 to 6 of 6
Thread: Does or has anyone run 245/75/16's on their D1 Tdi
    May 2008
    QLD - Sunshine Coast
    Hi everyone,
    Has anyone had success running 245/75/16's on their D1 Tdi. I have been offered some, they are in excallent condition. I am not sure if they are too big. I do a lot of highway miles and starting to get off road more and more.
    Whatchareckon.....?
    I ran this size Cooper STT's on my 97 Disco. You'll need a 2" suspension lift and also will have to trim the rear guards (camel cut) to make them clear the body.
    Oct 2007
    officer, Victoria
    its the size i run and all i needed was a camel cut (still havent done it) i am getting my lift shortly aswell but dont be too stressed if you dont have one
    St Helena,Melbourne
    4.28 MB
    Perfect size for a D1, 265's fit with not much more work .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Daisy Hill Queensland
    I have run that size MTR on my 97 Disco since 01, started them on standard suspension and did a 4 day tour of the Vic high country like this (staircase included)
    I am not sure what a camel cut is however the only mod I have had to do is bend a 45deg bend in the lower trailing corner of the rear guard and pull the lower edge out slightly.
    I have had them fitted on both the alloy and steel factory rims and have had no part of the side wall come in contact with the body work.
    The front tyres will rub at full lock unless you wind out the steering bump stops, however I have mine set for the smaller tyres and when running the 245/75/16 I will just back off the steering to stop the rubbing.
    The other thing they did for me was correct the speedo, so with them on the speedo is correct however the odo reads a little slow Approx 1km per 100km.
    You should find someone with that size to try them out
    Danny
    :TakeABow:LAND ROVER
    Don't Follow Me, I'm in a "Land Rover", You WON'T make it.
    aut viam inveniam aut faciam
    May 2008
    Hey Danny,
    Thanks mate, very encouraging. Much appreciated... All looks pretty positive so far.
    Starting to hook up with some folks now I have some time again..... bin an had a bit on......
