Results 1 to 8 of 8
Thread: alternator
    wells Guest
    alternator
    howdy all , what alternator have you guys replaced the originals with ,or are we stuck with the original one ? mines ok but i like to be prepared . i havnt been able to find to much info on this .thanks in advance
    Depends what sort of Rangie you have.
    I have an 85A alternator from a falcon (Au I think). The auto elec just changed over the pulley for me and it almost bolted straight in.
    wells Guest
    oh sorry , yes its a 89 RRC 3.9
    Bayswater, Melbourne
    hey - I have one to suit if you want...
    I have 3 at the moment. Where are you?
    Does the 3.9 run v belts or serpentine.
    What size alternators do you have?
    the 3.9 will take the early holden/ford 65 amp alternator the original pulley on them is a mickey hair out but near enough to work if you have the belt driven units.
    if you have the serpentine belt use the same alternator and swap pulleys
    wells Guest
    great .i have the belt drive so it looks like i have some options !
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    Not sure if you have seen this, but I converted mine to a Bosch unit from a Bitsmissing Magna.
    V8 Disco - Bosch alternator swap
