Results 1 to 6 of 6
Thread: Brake Fluid Pot
    GSKeeper Guest
    Brake Fluid Pot
    G'day All,
    I've just fitted anew master cylinder to the S11A SWB and noticed a slight weep from the bottom outlet of the brake fluid tin pot.
    I've stripped the pot down and it is in good order.
    What should I seal the bottom outlet with??
    Fibre washer, Copper washer, alloy washer??
    Thanks & Cheers
    Ben
    Any of them should work, but I would prefer the metal ones as with the fibre one there is the possibility of fibres getting into the fluid, and these could result in leaky seals. I am not sure what was used originally though - mine has been replaced with a plastic one while still in the army.
    Cessnock NSW
    G'day All, From memory they were thin rubber washers cheers Dennis
    GSKeeper Guest
    Thanks for the advise fellas,
    There were remnants of a rubber seal on the pot when I pulled it down, but I don't have any break fluid friendly rubber on hand.
    I might just experiment with a couple of plastic washer wod punched out of the break fluid container....at least I know it will handle the break fluid......I'll let you know how it goes.
    Ben
    Oct 2003
    Godwin Beach Qld
    G'day GSKeeper
    Any brake service/Parts Coy. should be able to supply a rubber/ fibre/plastic with the desired hole size, or your local friendly REPCO outlet should be able to supply one
    I went to a bearing shop and asked for an O-ring that is stable in brake fluid. It has worked for a number of years now.
    Aaron.
