Results 1 to 10 of 14
Thread: How many K's is too many
    Adelaide Hills
    Hi
    I am coming back to the light side and looking to get a discovery after a brief go with something Japanese. Had one in the UK and loved it.
    My question is, is 250,000 k's too many for a 1997 TDI 300 SE as in is it past it's usable life?
    The car has almost full service history and I am told had all belts changed at correct times, but I am yet to inspect books.
    Any thought would be appreciated.
    Foot of the Otways
    Hi Mate , i have a disco of the same age K's and motor . I have had trouble with mine but i'm starting to think it wasn't looked after as well as the last owner had said . I don't think that 250,000 is to many . My theory is if you look after it . it will look after you . I had some dill put gearbox oil in the box instead of the ATF it's meant to have . I'm replacing the front wheel bearings as one fell to bits on me and my 300tdi is due for the belt change . Other than that i love my disco and can't wait to get it out the bush .
    Jun 2008
    Shropshire, UK
    250,000k's is only 155,000 miles (You'll understand it more in miles coming from the UK! )
    That's hardly anything for a "well looked after" diesel, of any make and model....
    When I had my 300TDi back in blighty I was under good authority that they were good for about 350,000 miles (560,000k's for the Aussies! ) if properly maintained with regular service intervals and some TLC.
    ..:: KIEREN ::..
    2000 Disco II Auto V8
    (with knackered head gasket!)
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Our 200tdi disco has 370,000km's on it and we have only had afew miner isues.
    TIM.
    ACT
    Mate's has done 500,000kms and still going strong despite him being slack with servicing and not changing injectors (at least not in past 200K kays)! I guess with the variable build quality of LRs, sometimes you get lucky!
    Always looking for creative new ways to get bogged... :whistling:
    76 RR...sold coz fuel was expensive at 70c/l :eek:
    93 200 Tdi Disco...old faithful...sold to make way for...
    99 Td5 Disco ACE...nice drive...hopefully reliable...
    As with almost any Landrover, condition (and service history) is more important than actual kilometre figure. I would certainly not discount one with that mileage, but as with any second hand vehicle, particularly a relatively older one, check condition (and history as far as you can) carefully.
    Feb 2005
    i have 250K on mine, she is rough around the edges but the drive line has been well maintained....
    Foot of the Otways
    Your beasty looked pretty good to me .
    Capalaba.Q.L.D.
    interesting, my 95 tdi really started to run well AFTER 450000ks.It had over560ks when traded,(100 when bought)and was still going strong.Normal servicing,and mostly towing camper trailers and rather large boats.
    Only odd problem was some clown also filled gearbox with hd90.Had a bit of fun cleaning it out,otherwise all good. Oh and clutch pivot replaced at 490ks
    Adelaide Hills, SA
    Thumbs up
    Our early 94 300Tdi has 285K on it & is reliable (touch wood). It has a pretty complete service history and seems well looked after.
    I just had the timing belt replaced. A recored radiator was put in & with a mod to the baffle plate (supposed to be better for hot Australian summers than the original radiator baffle plate)...these were preventative maintenance, it wasn't actually running hot or using coolant (cheaper to do while the engine is in pieces for the timing belt).
    I'm told that the only thing 300Tdi's don't like is getting hot. Ours has certainly been good to us so far.
    Paul.
    Paul
    1971 IIA ute, 186 (Betsy)
    they're not dents, they're character...
