Results 1 to 4 of 4
Thread: park assist sensors
    Brisbane,some of the time.
    park assist sensors
    hi,got park assist sensors on the rear of the d2.The audible alarm is on all the time,and the light on the on/ off switch is flashing.This is only happening while in reverse.
    I recon one sensor is not working,does anyone know how to tell if one is faulty?
    They are factroy fitted ones,not after market.
    thanks in advance
    Douglas Park, NSW
    It looks like substitution is the only way .
    From the workshop manual:
    Diagnostics
    The PDC ECU has no diagnostic connection to enable faults to be retrieved using TestBook/T4. An on-board diagnostic routine monitors the system and alerts the driver to a system fault by emitting a tone from the sounder.
    If a PDC system fault has occurred, the sounder will emit a continuous tone for 3 seconds and the PDC switch LED will flash continuously when reverse gear is selected
    Melbourne, Australia
    thanks in advance
    Paul,
    Try disabling the system bu pushing the button when in reverse and then try enabling it again.
    When I had a broken sensor the alarm squealed permanently. If it is a faulty sensor and the circuit is broken, I would expect the same to happen. Best way to check is to put the vehicle in reverse and have somebosy put a hand in front of each sensor - if the alarm sounds it's working.
    If not, pull each one out and check the plug connection. They are easy to remove, just push it from behind, gice it a quarter turn and pull it out (towards the front of the vehicle if that makes sense)
    If all that fails, you might have to see a dealer.
    Franz
    2004 Discovery Td5 Classic
    Rang MR auto,they havent worked on them
    Had a real good look at all the sensors & found one had come apart,looks like it has been damaged ,so ordered a new one.Have tried to put it together ,but couldnt.
