Results 1 to 10 of 16
Thread: Changing D2 Fuel Pump - TD5
    Cooroy, QLD
    Hi All,
    didn't find much here when searching for how to change my D2 TD5 fuel pump, so thought I would post some tips post-job... First of all, the symptoms (loss of power and sluggish - wont go over 40kmh) were very similar to the turbo hose de-lamination (which happend a year ago) - so check that first! If your car has over 150k on it and you have already done the hose, then its quite likely its the fuel pump (or the oil in harness, check other threads for that).
    1. Quite a straight fwd job, if you change your own oil and filters then you can tackle this job I reckon. You need a few screwdrivers (phillips and flat), a pair of needle nose pliers and a hammer - easy!
    2. The pump is located in the top of the tank, but you dont need to drop the tank in the D2 - just remove the side bins (or seats) and pull up the carpet (more on this later). I have bins, so thats what I describe here - if you have seats then you will need to remove those (I have no idea what they even look like!).
    3. The new pump does not (at least in my case) come with the rubber gasket for the top of the tank lip - you need to keep the old one. I just gave mine a good wash in soapy water and swapped it over - no worries.
    4. Removing the retaining ring that holds the pump in place can be done (carefully) with a hammer and screwdriver - a couple of good whacks to get it moving then it will turn by hand. You need to press down on the top of the pump as it is spring loaded, otherwise the ring will be tight all the way out.
    5. The elec connector for the pump is a little fragile (mine was anyway) so be careful and use a small screwdriver to push the clips in before lifting off. If you break the clips (as I did) then a bead of silicon around the connector before refitting will ensure it doesn't vibrate loose.
    6. The fuel lines into the pump are colour coded (nice) as are the blanking plugs on the new pump - you cant go wrong here. A pair of needle nose pliers are all that is needed to remove the connectors for the lines (just squeeze them in and the lines pop out - easy when you see the connector).
    7. Removing and replacing the trim in the rear area is the biggest job. Be aware there are 4 press-in style trim clips, 3 you can see and one hiding behind the vent right at the back of the side bin panel - remove the vent and you will see the last clip - they are round-headed with a ribbed prong A flat screwy will leaver them out enough to grab with your fingers (or pliers) and pull out. There are also 3 phillips head screws - 2 under little covers each side of the rear window (use a small screwy to remove the cover) and one in the piece that covers the seat belt mechanism. Once you get all these clips and screws out the side bins will come straight out (pull from the bottom) - I just tilted the rear seats right fwd and pushed the bins into that space. The carpet then comes up easily (dont worry about the rear strip holding the carpet down, you dont need to remove that) - when refitting the carpet just use a large screwy to push it back under the strip. I found a lot of moisture under the carpet so I left it up for a week to dry after...
    8. The pump itself is under the circular plate in the floor - 6 phillips head screws and its off.
    9. To restart the car afterwards you need to follow the procedure for running out of fuel (in the owners manual) - basically cycle the key on/off about 5 times (follow the owners manual please!). You will hear the pump priming up when you do this - once it is all quiet (took about 10 cycles for me but my pump had failed and the car stopped, so the lines were empty) then its ready to go!
    All in all I reckon this took about 2 hours. I left the carpet up and the pump over off until I had filled the tank and driven around for a bit - just to check for leaks. I recommend you do this too.
    You can buy the pump for just under $500 - 2 hours of your time and you save the other $X a stealer or workshop would charge (I was quoted $1300!)... Well worth it in my books.
    Sorry there are no pics - I didn't really think about it until it was all over! Feel free to ask Q's or provide comments.
    Adam
    Ermington, NSW, Au
    Well this is scary. I had a similar problem at the same time. I searched for info like this the night before you posted and did a small write up as well. I only found this post today.
    Here's a link to my thread for future reference.
    TD5 fuel pump - It should make some noise, right?
    2012 110 Defender
    Normanhurst, NSW
    [quote] 4. Removing the retaining ring that holds the pump in place can be done (carefully) with a hammer and screwdriver - a couple of good whacks to get it moving then it will turn by hand. You need to press down on the top of the pump as it is spring loaded, otherwise the ring will be tight all the way out.[end quote]
    Attached picture of a hand made 'special' tool for removing Td5 fuel pumps without using the 'hammer and screwdriver method. Makes the job that that little bit easier and to carry one amongst a group on a trip could be worthwhile.
    The 1/2" socket drive makes it really easy to press down while turning and the two 'fingers' exert equal force on each side of the retaining ring.
    Roger
    NSW SW Slopes
    Quote Originally Posted by Xtreme View Post
    Roger
    Can you give the distance between the fingers and how long do they need to be please?
    TIA Graeme
    Normanhurst, NSW
    TIA Graeme
    No problem - provided you're not in a hurry.
    I'm away from home at present and don't have the tool with me. However, I'll measure it up when I return home and let you know.
    If you haven't heard from me within a couple of weeks, then send me a reminder.
    Roger
    Cooroy, QLD
    Hey, I like that tool! I thought about making something similar but was too lazy...
    NSW SW Slopes
    Roger
    That'll be great, thanks.
    I carry a spare pump and pressure gauge and may as well carry a tool that avoids the use a hammer.
    flybum Guest
    flybum
    will also be interested in sizes so i can make one cheers
    May 2003
    On The Road
    Thanks Adam,,
    straight to--
    The Good Oil
    Normanhurst, NSW
    Quote Originally Posted by flybum View Post
    Sorry for delay in answering the original request for the tool dimensions and thanks for this recent reminder.
    The 'legs ' of the tool are 45mm long, 10mm square section, 110mm apart (130mm OD) and the bottom of the legs are radiused. The cross piece I used is 25mm SHS (just what I had lying around) and on top of this, in the centre, is welded an old socket, giving me a 1/2" square drive for the socket tool.
    If this is not clear, let me know and I'll take a few more pictires at different angles.
    Roger
