Thread: ITEMS THAT NEED RECTIFICATION FOR R'WORTHY
    Aug 2008
    Smile ITEMS THAT NEED RECTIFICATION FOR R'WORTHY
    On my Feb 85 COUNTY for new registration after purchase from interstate. If I could get some hints or answers to the following;
    Reverse lights? did this model have them? or is a manual switch OK?
    RHand rear light brake? can you still buy them?
    Windscreen washers Repair/or Replace with new aftermarket type?
    Seatbelts ? both front ones? they looked allright to me.
    Rear mudflaps? They also looked allright, they are wide enough & secured with a chain ?
    Oil leak at pto output shaft?
    Engine oil leaks? didn't know she had any??? no signature on driveway? or marking of her area?
    Front swivel leaking?
    Both lefthand tie rod ends?
    Remove both ants {radio & uhf);and
    Adjust handbrake? It's a landrover? only kidding.
    I've only received a copy of the report at this stage I shall see/speak this morning to the mechanic.
    Dennis_G
    Last edited by Dennis_G; 2nd October 2008 at 06:02 AM. Reason: When you drive the BEST, you wave at the rest...
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    It came from standard with half those problems
    in the wild New England, NSW
    inspection sounds a bit severe.... what state and who was the inspector?
    Quote Originally Posted by Dennis_G View Post
    Yes. But note that if it is a diesel, the reversing light only comes on if the engine is running and producing oil pressure - if the mechanic is unfamiliar with them it is likely he only tested the reversing light with the engine stopped. I don't think a manual switch is acceptable for this date.
    All lights for this model are readily available from specialist Landrover suppliers. But a non working brake light is likely to be either the bulb or a faulty earth on the light.
    Probably replace the pump with an aftermarket one - I have done this twice on mine over the years.
    Belts are likely to have damage from being caught in the door. Probably still OK in reality, but I would replace them if there is any doubt.
    What is his concern with them then?
    Oil leaks from all transfer case outputs are not uncommon - usually new seals will at least temporarily fix them.
    May or may not have them - degreasing everything before inspection is usually worthwhile.
    Not uncommon, needs at a minimum the seal replacing, possibly swivel preload adjusting. In many cases the problem can be sidestepped by using semi-liquid grease ("one-shot") in the swivel, but if the preload needs adjusting, it needs adjusting.
    If they are loose or have damaged boots, they must be replaced.
    Remove both ants {radio & uhf);and ??
    Dennis_G
    Strictly speaking all oil leaks are prohibited, but how this is interpreted varies with the person doing the inspection.
    Aug 2008
    Thankyou gents,
    Yes I reckon he was a bit over the top, BUT it will be right now.
