Results 1 to 6 of 6
Thread: Exending the Range of my wireless network
    Toowoomba QLD
    I've just installed a simple wireless router at home with the hope that I might get reception for the laptop in my shed (steel). The laptop has a PCMIA card with no external antenna.
    With the front roller doors open, I get a very weak signal but not enough to transfer any data. The signals not much better outside the shed either.
    The shed is about 50m from the house and the router is at the other end of the house so the signal is passing through the (timber) house.
    What are the best options for extending the range and getting a signal in the shed?
    These are some of the things I've thought about but havent spent any money on yet in case they wont work:
    -external antenna on the router?
    -range extender repeater - at the other end of the house closer to the shed?
    -USB thingy on the laptop with external antennal?
    I dont really want to relocate the router as this would involve running ethernet cable which was part of the reason for going wireless in the first place.
    Hervey Bay, Qld
    Quote Originally Posted by mark2 View Post
    these are your two best options.....the latter is prob the best other wise the connection through the second will slow your speed
    Kyabram, VIC 3620
    I had the same issue - I just put an external antenna on the router, works perfectly now - even with all the doors shut on the shed
    Cost me about $50.00
    darwin
    2 jam tins and 50 metres of string [keep string tight]
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    daRangie Guest
    Have a look here. www.freeantennas.com
    As you have some signal, one of those free antennas might boost the signal enough to make it useable. I use the ez-10 and was surprised by its effectiveness.
    May 2008
    Lismore, NSW
    Use an external antenna. Make sure it is a high gain antenna for best range.
    Warren
    Currently Landroverless - Still interested
    Formerly: 2003 D2a Update TD5 Auto. Platinum edition. ARB Bar, 36" LED light bar, cargo barrier, dual batteries.
